[GRASS-dev] t.rast.aggregate test mysteriously worked one day
Vaclav Petras
wenzeslaus at gmail.com
Wed Apr 29 14:56:22 PDT 2015
I've noticed that t.rast.aggregate "relative" test succeeded one day but
generally fails:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-27-13-32/report_for_nc_spm_08_grass7_nc/temporal/t.rast.aggregate/test_aggregation_relative/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-28-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.aggregate/test_aggregation_relative/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-29-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.aggregate/test_aggregation_relative/index.html
When I run it locally:
# in grass session in a new mapset
cd temporal/t.rast.aggregate/testsuite
python test_aggregation_relative.py
I get these errors:
ERROR: Unable to make mapset element cell_misc/b_3
(/grassdata/nc_spm_testing/practice5/cell_misc/b_3): File exists
b_3 is the same name which is visible in (different) error messages in the
tests:
ERROR: Unable to update raster map
<b_3 at __temporal_t_rast_aggregate_test_aggregation_relative>.
The map does not exist.
ERROR: Unsupported relative time unit type for raster map
<b_1 at __temporal_t_rast_aggregate_test_aggregation_relative>:
None
I looked to the test but I was not sucesful. If somebody would like to look
at it, remember that tearDownClass class method runs just once after all
test_ methods are executed while tearDown method runs after each test_
method. Also remember that the order of runs is undefined. Perhaps the
error messages needs to be enhanced in the actual code.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150429/f28bc1d5/attachment.html>
