[GRASS-dev] A few powerpc64-suse-linux compilation issues
Markus Neteler neteler at osgeo.org
Sat Aug 1 09:54:45 PDT 2015
I checked the logs of openSUSE_..._PowerPC at
https://build.opensuse.org/package/show?package=grass&project=Application%3AGeo
and found a few compilation issues - any ideas how to fix them?
Markus
cd lib/db/dbmi_base/
[  109s] error.c: In function 'db_noproc_error':
[  109s] gcc  -O2  -fPIC
-I/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/include
-D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64   -DPACKAGE=\""grasslibs"\"
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.powerpc-unknown-linux-gnu/value.o -c
value.c
[  109s] error.c:159:6: warning: type of 'procnum' defaults to 'int'
[-Wimplicit-int]
[  109s]  void db_noproc_error(procnum)
[  109s]       ^
[  109s]
[  139s]
GISRC=/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/demolocation/.grassrc70
GISBASE=/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu
PATH="/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/bin:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/bin:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/etc/python:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/bin:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/scripts:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/lib:/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/lib:"
LC_ALL=C ./ctypesgen.py --cpp "gcc -E  -D_LARGEFILE_SOURCE
-D__GLIBC_HAVE_LONG_LONG" -lgrass_display.7.0.1
/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/include/grass/display.h
/home/abuild/rpmbuild/BUILD/grass-7.0.1/dist.powerpc-unknown-linux-gnu/include/grass/defs/display.h
-o OBJ.powerpc-unknown-linux-gnu/display.py
[  139s] Status: Preprocessing /tmp/tmpPcZ3UU.h
[  139s] Status: gcc -E  -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpPcZ3UU.h
[  139s] Status: Parsing /tmp/tmpPcZ3UU.h
[  139s] Error: /usr/lib/gcc/powerpc64-suse-linux/5/include/stddef.h:427:
Syntax error at '__attribute__'
Syntax error at '('
[  139s] Error: /usr/lib/gcc/powerpc64-suse-linux/5/include/stddef.h:428:
Syntax error at '('
[  139s] Status: Processing description list.
[  139s] Status: Writing to OBJ.powerpc-unknown-linux-gnu/gmath.py.
[  139s] Status: Wrapping complete.
[  141s] Status: Preprocessing /tmp/tmpPQ7enI.h
[  141s] Status: gcc -E  -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
"-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpPQ7enI.h
[  141s] Status: Parsing /tmp/tmpPQ7enI.h
[  141s] Status: Processing description list.
[  141s] Warning: Member "from" of Struct "DateTime" has been renamed to
"_from" because it has the same name as a Python keyword.
[  141s] Warning: Member "def" of Struct "Option" has been renamed to
"_def" because it has the same name as a Python keyword.
[  141s] Warning: Could not parse macro "#define serialize_int32_le(buf,x)
do { ( buf ) [ i0 ] = ( ( x ) >> i0 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >>
i8 ) & i255 ; ( buf ) [ i2 ] = ( ( x ) >> i16 ) & i255 ; ( buf ) [ i3 ] = (
( x ) >> i24 ) & i255 ; } while ( i0 )"
[  141s] Warning: Could not parse macro "#define serialize_int32_be(buf,x)
do { ( buf ) [ i0 ] = ( ( x ) >> i24 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >>
i16 ) & i255 ; ( buf ) [ i2 ] = ( ( x ) >> i8 ) & i255 ; ( buf ) [ i3 ] = (
( x ) >> i0 ) & i255 ; } while ( i0 )"
[  141s] Status: Writing to OBJ.powerpc-unknown-linux-gnu/gis.py.
[  141s] Status: Wrapping complete.
[  268s] Fatal Error: Mismatch between the program and library build
versions detected.
[  268s] The library used 2.8 (no debug,Unicode,compiler with C++ ABI
1008,STL containers,compatible with 2.6),
[  268s] and wxPython used 2.8 (no debug,Unicode,compiler with C++ ABI
1009,STL containers,compatible with 2.6).
[  268s] ../../include/Make/Html.make:14: recipe for target
'd.rast.edit.tmp.html' failed
[  268s] make[3]: *** [d.rast.edit.tmp.html] Error 1
[  268s] rm d.rast.edit.tmp.html
[  268s] make[3]: Leaving directory
'/home/abuild/rpmbuild/BUILD/grass-7.0.1/scripts/d.rast.edit'
[  298s]
LC_ALL=C python core/toolboxes.py > xml/menudata.xml
[  299s] Fatal Error: Mismatch between the program and library build
versions detected.
[  299s] The library used 2.8 (no debug,Unicode,compiler with C++ ABI
[  299s] and wxPython used 2.8 (no debug,Unicode,compiler with C++ ABI
[  299s] /bin/sh: line 1:  5235 Aborted
[  299s] Makefile:40: recipe for target 'xml/menudata.xml' failed
[  299s] make[4]: *** [xml/menudata.xml] Error 134
[  299s] make[4]: Leaving directory
'/home/abuild/rpmbuild/BUILD/grass-7.0.1/gui/wxpython'
[  299s] Makefile:29: recipe for target 'default' failed
[  299s] make[3]: [default] Error 2 (ignored)
[  299s] make xml/module_tree_menudata.xml
[  299s] make[4]: Entering directory
[  299s]
LC_ALL=C python core/toolboxes.py "module_tree" >
versions detected.
[  299s] /bin/sh: line 1:  5241 Aborted
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150801/bccf7194/attachment.html>
