[GRASS-dev] g.extensions problems
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Mon Aug  3 07:06:03 PDT 2015
There seems to be a problem with addons metadata when installing using
g.extension. Installing of addons is successful, but with the following
error message:
*WARNING: Unable to parse
'https://svn.osgeo.org/grass/grass-addons/grass7/modules.xml
<https://svn.osgeo.org/grass/grass-addons/grass7/modules.xml>': syntax
error: line 1, column 49WARNING: No addons metadata available. Addons
metadata file not updated.*
Also, when selecting an addon in the 'fetch and install addon' screen
(g.extension gui), there is no description in the bottom like there usual
is.
Furthermore, when opening the g.extension window, the repository address is
not automatically pre-filled as usual.
Running GRASS master revision 65818 on Ubuntu 14.04
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150803/486c032e/attachment.html>
