[GRASS-dev] installing v.mapcalc fails
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Aug 3 07:10:14 PDT 2015
On Sun, Aug 2, 2015 at 11:42 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On Sun, Aug 2, 2015 at 8:51 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Aug 2, 2015 at 8:45 PM, Paulo van Breugel
>> <p.vanbreugel at gmail.com> wrote:
>> > Hi Markus
>> > On Linux (Ubuntu 14.04). Tried it again, with another error message this
>> > time:
>> > g.extension extension=v.mapcalc
>> > svnurl=http://svn.osgeo.org/grass/grass-addons/grass7
>> > Fetching <v.mapcalc> from GRASS-Addons SVN repository (be patient)...
>> > Compiling...
>> > yylex.c:9:27: fatal error: v.mapcalc.tab.h: No such file or
>> > directory
>> > #include "v.mapcalc.tab.h"
>> > compilation terminated.
>> > make: *** [OBJ.x86_64-unknown-linux-gnu/yylex.o] Error 1
>> > ERROR: Compilation failed, sorry. Please check above error messages.
>> I tried on my Fedora 21 box:
>> GRASS 7.0.2svn (nc_spm_08_grass7):~ > g.extension extension=v.mapcalc
>> Compiling...
>> In file included from /usr/include/stdio.h:27:0,
>> from number.c:3:
>> /usr/include/features.h:148:3: warning: #warning "_BSD_SOURCE and
>> _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
>> # warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use
>> _DEFAULT_SOURCE"
>> Installing...
>> Updating addons metadata file...
>> Installation of <v.mapcalc> successfully finished
>> No issues...
>> The file "missing" seems to be generated on the fly:
>> [neteler at oboe v.mapcalc]$ grep v.mapcalc.tab.h *
>> Makefile:yylex.c: v.mapcalc.tab.h
>> Makefile:.INTERMEDIATE: v.mapcalc.tab.c v.mapcalc.tab.h v.mapcalc.output
>> grep: OBJ.x86_64-unknown-linux-gnu: Is a directory
>> grep: plugins: Is a directory
>> yylex.c:#include "v.mapcalc.tab.h"
>> Do you have the 'bison' program installed? That's needed.
> Yes (it is, I think, also needed to compile grass itself?). Just to be
> complete, off all the ones I tried, this is the only one not installing.
Tried again to install v.mapcalc after updating my grass 7.1, the module
installed successfully. Thanks Markus
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150803/e15154b8/attachment.html>
