[GRASS-dev] [GRASS-user] v.neighors error:region do not overlap
Anna Petrášová
kratochanna at gmail.com
Wed Aug 5 07:51:54 PDT 2015
On Wed, Aug 5, 2015 at 10:25 AM, patrick s. <patrick_gis at gmx.net> wrote:
> UPDATE:
> The error of v.neighbors does not appear when importing points only for a
> region: "v.in.ogr -r"
> So definitely a problem of v.neighbors.
Looking at v.neighbors source code [1], the message seems wrong, it should
be something like "Some input vector points are outside of computational
region". But I don't understand why this should prevent v.neighbors from
running. Perhaps this test could be removed?
Anna
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.neighbors/main.c#L95
> Patrick
> On 01.08.2015 23:56, Markus Neteler wrote:
>> On Wed, Jul 29, 2015 at 4:40 PM, patrick s. <patrick_gis at gmx.net> wrote:
>>> Hi,
>>> I need to run v.neighbors on multiple datasets for the identic region
>>> (extend and resolution). One dataset has observations outside of this
>>> region, and causes an error: "ERROR: Input vector and computational
>>> region
>>> do not overlap." However, viewing the extend in v.info and r.info (see
>>> below) and overlaying the layers in the GUI, I see overlaps for 90% of my
>>> points. Is this expected behavior or do I miss something? (GRASS70 from
>>> Repos, OS:Ubuntu 15.04)
>>> #Code
>>> r.in.gdal in="./00_REFERENCE/reference_map.tif" out=region_ref --o
>>> g.region rast=region_ref
>> Just to be sure, please post
>> g.region raster=region_ref -p
>> I generated a location with epsg:2056 (is that the right one for
>> CH_1903+ ?) and there is indeed map overlap.
>> But just to be sure that the computational region is right, too.
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150805/8a09e8fc/attachment.html>
