[GRASS-dev] Error when compiling using homebrew - says liblas but is gdal???
Rainer M Krug
Rainer at krugs.de
Wed Aug 5 09:12:07 PDT 2015
Mac OS X Yosemite, homebrew recipe.
| Checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
| rm: conftest.dSYM: is a directory
| checking whether to use libLAS... yes
| checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
| configure: error: *** Unable to locate libLAS library.
The config.log says:
| onfigure:6164: checking whether to use libLAS
| configure:6181: checking for liblas-config
| configure:6238: clang -o conftest -g -O2 -I/usr/local/opt/gettext/include -I/usr/local/Cellar/liblas/1.8.0/include -I/usr/local/include -I/usr/local/include -I/usr/local/include conftest.c -L/usr/local/Cellar/liblas/1.8.0/lib -llas -llas_c -L/usr/local/lib /usr/local/lib/libboost_program_options-mt.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib /usr/local/lib/libgeotiff.dylib /usr/local/lib/libtiff.dylib 1>&5
| clang: error: no such file or directory: '/usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib'
| configure: failed program was:
| #line 6231 "configure"
| #include "confdefs.h"
| #include <liblas/capi/liblas.h>
| int main() {
| LASReader_Create("foo");
| ; return 0; }
| configure:6253: clang -o conftest -g -O2 -I/usr/local/opt/gettext/include -I/usr/local/Cellar/liblas/1.8.0/include -I/usr/local/include -I/usr/local/include -I/usr/local/include conftest.c -L/usr/local/Cellar/liblas/1.8.0/lib -llas -llas_c -L/usr/local/lib /usr/local/lib/libboost_program_options-mt.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib /usr/local/lib/libgeotiff.dylib /usr/local/lib/libtiff.dylib 1>&5
| #line 6246 "configure"
| int main() {
| ; return 0; }
So the error is somewhere in the config logic and gdal?
gdal is installed - but /usr/local/Cellar/gdal/1.11.2_2
The installation works when I install without liblas.
Any suggestions on how to proceed?
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150805/1f183cd3/attachment.pgp>
