[GRASS-dev] OSX 10.11 Compiling
Rainer M Krug
Rainer at krugs.de
Thu Aug 6 06:30:10 PDT 2015
OK - I tried the installation of grass 70 from osgeo4mac and it has the
same error. I have reported it on their website (see
https://github.com/OSGeo/homebrew-osgeo4mac/issues/102)
So it is not a 7.1 issue.
Cheers,
Rainer
Rainer M Krug <Rainer at krugs.de> writes:
> Carlos Grohmann <carlos.grohmann at gmail.com> writes:
>> Hi
>> I never installed OS X on a virtual machine, can't help much there.. (I'm
>> using yosemite as primary machine and El Capitan on a secondary one)
> OK - I will see how it goes. Maybe a second HDD is the easiest option.
>> While we are here, I tried the homebrew tap for 7.1svn on a Yosemite
>> machine and it didn't worked.
> Could you give me the options you used for
> | brew install --HEAD grass-71
> so that I can check? because on Travis-ci the default installation is
> installing without errors - I am trying it just now at
> https://travis-ci.org/rkrug/homebrew-experimental
>> First I tried to install with libLas, add although it installed libels
>> correctly, it can't find the library when running GRASS'configure
>> :==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
>> --with-
>> checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
>> rm: conftest.dSYM: is a directory
>> checking whether to use libLAS... yes
>> checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
>> configure: error: *** Unable to locate libLAS library.
>> Then I tried with libels and it went OK, but when I run:
>> Serenity:~ guano$ /usr/local/bin/grass71
>> Traceback (most recent call last):
>> File "/usr/local/bin/grass71", line 54, in <module>
>> ENCODING = locale.getdefaultlocale()[1]
>> File
>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
>> line 511, in getdefaultlocale
>> return _parse_localename(localename)
>> File
>> line 443, in _parse_localename
>> raise ValueError, 'unknown locale: %s' % localename
>> ValueError: unknown locale: UTF-8
>> Serenity:~ guano$
> I have everything (including python) in homebrew and I can install it,
> although I have not tested any additional options.
> I just added two more test cases / envelopes on travis-ci (--with-liblas
> and --with-openblas) to test this and they are running at the moment ...
> You can see them at
> https://travis-ci.org/rkrug/homebrew-experimental/builds/74242734
> And the --with-liblas fails there as well. OK.
> I added the -v for the v=compile to get a better picture ...
> https://travis-ci.org/rkrug/homebrew-experimental/builds/74248159
> same errors.
> I found the following:
> grass70 not detecting latest source build of libLAS (1.7.0)
> https://trac.osgeo.org/grass/ticket/2065
> And the only reference I see is that liblas newer than 1.7 is
> installed, but homebrew installs 1.8 - so this is not the problem.
> OK - I think I narrowed it down: it seems that the problem is gdal.
> I will open another subject with this.
> Cheers,
> Rainer
>> any ideas?
>> thanks
>> Carlos
>> On Tue, Aug 4, 2015 at 10:52 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>> > Hello Rainer (and devs)
>>> > I think you only need to join the beta program (although I have the free
>>> > developer account, just to be able to download xcode-related tools like
>>> the
>>> > comand line tools).
>>> Thanks - I registered for the beta program an I am downloading El
>>> Capitan at the moment.
>>> Can you give any pointers how I can install it in Virtual Box as I do
>>> not want to interfere with my production machine and do prefer the
>>> flexibility of a virtual machine.
>>> I'll take a look at the errors when I have it installed - which might be
>>> in two weeks time as I will be on holiday next week.
>>> Thanks,
>>> Rainer
>>> > I'll summarise what I know so far about these issues:
>>> > - When compiling, I get a lot of errors. These are related to creating
>>> html
>>> > docs. As Glynn said, at this pint of compilation, the module is run
>>> > with --html-description
>>> > switch to get a list of its options. Any problems with wxpython will
>>> cause
>>> > an error here.
>>> > - Running make in the module directory show a call to
>>> > libgrass_gis.7.0.1svn.dylib,
>>> > but with the wrong path. It tries to load the library from the final
>>> > package path (after installation), which doesn't exists yet..
>>> > see the last lines of this output:
>>> > cd scripts/d.correlate/
>>> > GuanoAFBIOTA:d.correlate guano$ make
>>> > if [
>>> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
>>> > != "" ] ; then
>>> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
>>> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
>>> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
>>> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
>>> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
>>> > LC_ALL=C
>>> > --html-description < /dev/null | grep -v '</body>\|</html>' >
>>> > d.correlate.tmp.html ; fi
>>> > dyld: Library not loaded:
>>> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
>>> > Referenced from:
>>> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
>>> > Reason: image not found
>>> > make: *** [d.correlate.tmp.html] Error 1
>>> > rm d.correlate.tmp.html
>>> > - Ignoring the error and creating the package will work, and the package
>>> > will install, although when run, the GUI will fail:
>>> >>>> from grass.pygrass import messages
>>> > File "<stdin>", line 1, in <module>
>>> > File
>>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
>>> > line 19, in <module>
>>> > import grass.lib.gis as libgis
>>> > File
>>> > "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
>>> > line 23, in <module>
>>> > _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
>>> > File
>>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
>>> > line 57, in load_library
>>> > raise ImportError,"%s not found." % libname
>>> > ImportError: grass_gis.7.0.1RC2 not found.
>>> > cheers
>>> > Carlos
>>> > On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com>
>>> wrote:
>>> >> Envoyé de mon iPhone
>>> >> Le 31 juil. 2015 à 23:07, Carlos Grohmann <carlos.grohmann at gmail.com> a
>>> >> écrit :
>>> >> Hi
>>> >> The homebrew formula doesn't really work on OSX 10.11 beta. In the log
>>> >> file (attached) I can see the same errors in compilation I got when
>>> tried
>>> >> to compile svn. They are related to html manual pages, but prevent
>>> >> installation from continue.
>>> >> As I do not have 10.11 beta I can't check it. But please let me (and
>>> >> osgeo4mac) know when you found a solution as I think it will also affect
>>> >> 6.4x and 7.0x versions.
>>> >> Do I have to have a developer account with apple to have access to the
>>> >> beta?
>>> >> Cheers
>>> >> Rainer
>>> >> Carlos
>>> >> brew tap rkrug/head-only
>>> >> ==> Tapping rkrug/head-only
>>> >> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
>>> >> remote: Counting objects: 4, done.
>>> >> remote: Compressing objects: 100% (4/4), done.
>>> >> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
>>> >> Unpacking objects: 100% (4/4), done.
>>> >> Checking connectivity... done.
>>> >> Tapped 1 formula (27 files, 116K)
>>> >> brew install grass-71
>>> >> Error: rkrug/head-only/grass-71 is a head-only formula
>>> >> Install with `brew install --HEAD rkrug/head-only/grass-71`
>>> >> Warning: You are using OS X 10.11.
>>> >> We do not provide support for this pre-release version.
>>> >> You may encounter build failures or other breakage.
>>> >> ==> Installing grass-71 from rkrug/homebrew-head-only
>>> >> Error: No available formula for nc_spm_08_grass7 (dependency of
>>> >> rkrug/head-only/grass-71)
>>> >> guano$ brew install --HEAD rkrug/head-only/grass-71
>>> >> --without-nc_spm_08_grass7
>>> >> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
>>> >> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
>>> >> ==> Patching
>>> >> patching file include/Make/Install.make
>>> >> Hunk #1 succeeded at 116 (offset 2 lines).
>>> >> --with-
>>> >> ==> make GDAL_DYNAMIC=
>>> >> appear in the error log. If you get an error building a library, you
>>> will
>>> >> also get errors from anything which uses the library.
>>> >> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
>>> >> make: *** [default] Error 1
>>> >> READ THIS: https://git.io/brew-troubleshooting
>>> >> If reporting this issue please do so at (not Homebrew/homebrew):
>>> >> https://github.com/rkrug/homebrew-head-only/issues
>>> >> GuanoAFBIOTA:~ guano$
>>> >> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
>>> >> carlos.grohmann at gmail.com> wrote:
>>> >>> Very interesting!
>>> >>> From the brew recipe, it looks that one needs all dependencies
>>> installed
>>> >>> via homebrew, is that right? I'm thinking that most will have
>>> Kyngsburie's
>>> >>> Frameworks already installed (at least GDAL). Same goes for wx-python.
>>> >>> best
>>> >>> Carlos
>>> >>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de>
>>> wrote:
>>> >>>> Anna Petrášová <kratochanna at gmail.com> writes:
>>> >>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer at krugs.de>
>>> >>>> wrote:
>>> >>>> >> Hi
>>> >>>> >> I just added a section / new page in the WIKI for installation of
>>> >>>> GRASS
>>> >>>> >> using homebrew. Please see
>>> >>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
>>> >>>> >> and
>>> >>>> >> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
>>> >>>> >> It would be great if some Mac / homebrew users would see if it
>>> works
>>> >>>> and
>>> >>>> >> give me comments here.
>>> >>>> > I will try to test it next week. Thank you for your efforts!
>>> >>>> Great - let me know how it goes, although I don't know if I will be
>>> able
>>> >>>> to reply as I am away and possibly only have very limited internet
>>> >>>> access.
>>> >>>> Thanks,
>>> >>>> Rainer
>>> >>>> > Anna
>>> >>>> >> Cheers,
>>> >>>> >> Rainer
>>> >>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>> >>>> >> Biology, UCT), Dipl. Phys. (Germany)
>>> >>>> >> Centre of Excellence for Invasion Biology
>>> >>>> >> Stellenbosch University
>>> >>>> >> South Africa
>>> >>>> >> Tel : +33 - (0)9 53 10 27 44
>>> >>>> >> Cell: +33 - (0)6 85 62 59 98
>>> >>>> >> Fax : +33 - (0)9 58 10 27 44
>>> >>>> >> Fax (D): +49 - (0)3 21 21 25 22 44
>>> >>>> >> email: Rainer at krugs.de
>>> >>>> >> Skype: RMkrug
>>> >>>> >> PGP: 0x0F52F982
>>> >>>> >> _______________________________________________
>>> >>>> >> grass-dev mailing list
>>> >>>> >> grass-dev at lists.osgeo.org
>>> >>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>> >>>> South Africa
>>> >>>> Skype: RMkrug
>>> >>>> PGP: 0x0F52F982
>>> >>> Prof. Carlos Henrique Grohmann
>>> >>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> >>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> >>> http://carlosgrohmann.com
>>> >>> http://orcid.org/0000-0001-5073-5572
>>> >>> ________________
>>> >>> Can’t stop the signal.
>>> >> ________________
>>> >> <02.make>
>>> South Africa
>>> Skype: RMkrug
>>> PGP: 0x0F52F982
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150806/aa05614e/attachment-0001.pgp>
