[GRASS-dev] Error when compiling using homebrew - says liblas but is gdal???
Rainer M Krug
Rainer at krugs.de
Thu Aug 6 06:35:02 PDT 2015
Glynn Clements <glynn at gclements.plus.com> writes:
> Rainer M Krug wrote:
>> | configure:6181: checking for liblas-config
>> | configure:6238: clang -o conftest -g -O2
>> | -I/usr/local/opt/gettext/include
>> | -I/usr/local/Cellar/liblas/1.8.0/include -I/usr/local/include
>> | -I/usr/local/include -I/usr/local/include conftest.c
>> | -L/usr/local/Cellar/liblas/1.8.0/lib -llas -llas_c
>> | -L/usr/local/lib /usr/local/lib/libboost_program_options-mt.dylib
>> | /usr/local/lib/libboost_thread-mt.dylib
>> | /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib
>> | /usr/local/lib/libgeotiff.dylib /usr/local/lib/libtiff.dylib 1>&5
>> | clang: error: no such file or directory: '/usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib'
> The configure script runs "liblas-config --libs" to obtain the
> libraries. liblas-config is saying that it needs
> /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib but the linker
> complains that the file doesn't exist.
> It may be that libLAS was built against a GDAL library which has since
> been removed. In which case, you need to either restore that library
> or re-build libLAS to use and existing version of GDAL (or without
> GDAL; the dependency is optional).
You are spot on! Great. Thanks a lot.
This solved the problem. I will add this to the test and to the WIKI
page.
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150806/b2476e9a/attachment.pgp>
