[GRASS-dev] OSX 10.10 Yosemite + Homebrew - Summary
Anna Petrášová
kratochanna at gmail.com
Fri Aug 7 11:48:49 PDT 2015
On Wed, Aug 5, 2015 at 10:33 AM, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> OK, this is a summary of what works and what doesn't work when installing
> GRASS 7.1svn through homebrew on OSC 10.10 Yosemite (still need to test
> these on El Capitan 10.11).
> 1) libLAS: although properly installed by homebrew, it's not found by
> ./configure:
> :==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
> --with-
> checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
> rm: conftest.dSYM: is a directory
> checking whether to use libLAS... yes
> checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
> configure: error: *** Unable to locate libLAS library.
> 2) so give up of liblas for now. The spearfish sample location also won't
> work, so install with:
> > brew install --HEAD rkrug/head-only/grass-71 --with-openblas
> --without-nc_spm_08_grass7
> 3) after installation, add these to .bash_profile:
> export LC_ALL=en_US.UTF-8
> export LANG=en_US.UTF-8
> export PYTHONPATH=`brew --prefix`/lib/python2.7/site-packages:`brew
> --prefix`/lib/python2.7/site-packages/wx-3.0-osx_cocoa
> :$PYTHONPATH
> And it works!
Hi Carlos and Rainer,
I am testing it now and the installation goes well, but I can't launch it
because it doesn't find wx. So I exported the PYTHONPATH as you did and
then I am getting:
Cleaning up temporary files...
Starting GRASS GIS...
This program needs access to the screen.
Please run with a Framework build of python, and only when you are
logged in on the main display of your Mac.
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Does anyone know what does it mean?
BTW, is there a way we could use wxPython 2.8 (32bit) instead of 3? Version
3 is not working very well on Mac yet, I tried to fix couple of things in
GRASS, but there are some bugs in the library itself.
Thank you,
Anna
> best
> Carlos
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150807/4b6ea75d/attachment-0001.html>
