[GRASS-dev] db.connect (-d flag) error in case of schema previously defined
Roberto Marzocchi roberto.marzocchi at gmail.com
Thu Aug 13 04:11:57 PDT 2015
Dear all,
trying to use "db.connect -d" in GRASS 7.0 I see a not correct behaviour:
I previously set up a schema (e.g of a PostGIS DB) GRASS do not remove the
schema, so I have to manually remove from VAR file. Perhaps there is a
better way to remove it, but I think that -d option need to remove also the
schema.
All the best,
R
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150813/995c1276/attachment.html>
