[GRASS-dev] Python scripts receiving input from the GRASS GUI?
Michel Wortmann wortmann at pik-potsdam.de
Thu Aug 13 07:32:30 PDT 2015
Dear Devs,
what would be the best and least invasive way of receiving input from
the grass GUI to use in python scripts. The following functionalities
are on my mind:
- when double-clicking a line in the dbmgr, trigger a script/function
using the line's content as input
- when selecting a feature in the map display, trigger a script/function
using the query results as input
I guess changing the effect of a dbmgr line double-click can only be
changed by fiddling with the gui/wxpython/dbmgr module files. Receiving
the select query results as input on the command line is in theory
possible with the 'Redirect to console' option in the select pop-up, but
how can I read the GUI console?
In case someone had similar intentions and has some clues, I would
appreciate hearing about them.
Best regards,
Michel
