[GRASS-dev] Seasonal temporal granularity
Sören Gebbert
soerengebbert at googlemail.com
Thu Aug 13 14:35:07 PDT 2015
Dear Markus and Luca,
feel free to implement user defined granularities in t.register. It
should be convenient to use something like "astro_seasons" as
identifier to apply the astronomical seasons to map layers that should
be registered in the temporal database.
However, the computed granularity of the resulting space-time dataset
will be 1 day, unless you modify the granularity computation in
lib/python/temporal/temporal_granularity.py to acknowledge user
defined granularities. Which would be really nice indeed.
Best regards
Soeren
2015-08-13 22:08 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Soeren,
> On Thu, Aug 13, 2015 at 5:55 PM, Sören Gebbert
> <soerengebbert at googlemail.com> wrote:
>> Hi Luca,
>> what kind of seasons do you think of?
> For example, we would need something like this (Northern hemisphere):
> - spring: 22/03/ .. 20/06/
> - summer: 21/06/ .. 23/09/
> - autumn: 24/09/ .. 20/12/
> - winter: 21/12/ .. 21/03/
> It would be *really* good to let the user decide the start/end date of
> the seasons.
> thanks
> Markus
