[GRASS-dev] grass-addons and nested module libraries
Pietro peter.zamb at gmail.com
Mon Aug 17 03:57:09 PDT 2015
Dear devs,
I've noticed that r.green module is installing his libraries in the wrong place:
$ # rm -r $GRASS_ADDON_BASE
$ g.extension extension=r.green
Fetching <r.green> from GRASS GIS Addons repository (be patient)...
Compiling...
Installing...
Updating addons metadata file...
ERROR: Unable to read manual page: [Errno 2] No such file or directory:
       '/home/pietro/.grass7/addons/docs/html/r.green.html'
that generate a tree directory like:
$ tree $GRASS_ADDON_BASE
├── bin
├── docs
│   ├── html
│   │   ├── grassdocs.css
│   │   ├── r.green.biomassfor.co2.html
│   ├── man
│   │   └── man1
│   │       ├── r.green.biomassfor.co2.1
│   │       ├── r.green.biomassfor.economic.1
│   └── rest
├── etc
├── libgreen
│   ├── checkparameter.py
├── libhydro
│   ├── basin.py
├── modules.xml
└── scripts
I would like that both the directories: libgreen and libhydro are
installed inside  $GRASS_ADDON_BASE/etc/r.green:
├── bin
├── docs
│   ├── html
│   ├── man
│   │   └── man1
│   └── rest
├── etc
│   └── r.green
│       ├── libgreen
│       │   ├── checkparameter.py
│       └──libhydro
│           ├── basin.py
├── modules.xml
└── scripts
I think the problem is due that when in the Makefile I create the
ETCDIR the LIBGREENDIR does not exist yet:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.green/libgreen/Makefile#L18
Therefore I've tried adding to the Makefile something like:
$ svn diff libgreen/Makefile
Index: libgreen/Makefile
--- libgreen/Makefile   (revision 65945)
+++ libgreen/Makefile   (working copy)
@@ -15,6 +15,9 @@
 default: $(PYFILES) $(PYCFILES) $(ETCDIR)/__init__.py $(ETCDIR)/__init__.pyc
+$(LIBGREENDIR):
+       $(MKDIR) $@
 $(ETCDIR):
        $(MKDIR) $@
But it continue to install libgreen and libhydro in the
$GRASS_ADDONS_BASE root...
NOTE: if I compile the module with: make MODULE_TOPDIR=$GISBASE both
the directories are created in the correct place:
$ ls -l $GISBASE/etc/r.green
total 8.0K
drwxr-xr-x 2 pietro pietro 4.0K Aug 17 12:52 libgreen/
drwxr-xr-x 2 pietro pietro 4.0K Aug 17 12:52 libhydro/
Why?
Someone has an idea on how I could/should fix this?
Pietro
