[GRASS-dev] [GRASS GIS] #2723: error when running v.krige
    trac at osgeo.org
    Mon Aug 17 11:19:34 PDT 2015
 Reporter:  pvanbosgeo  |      Owner:  grass-dev@…
     Type:  defect      |     Status:  new
 Priority:  normal      |  Milestone:
Component:  Default     |    Version:  svn-trunk
 Keywords:              |        CPU:  Unspecified
 Platform:  Linux       |
 When I use the "plot/refresh variogram" button, I am getting an error
 message:
 Command: v.out.ogr
 ... usual text about v.out.ogr
 /usr/lib/python2.7/dist-packages/rpy2/robjects/functions.py:106:
 UserWarning: Error in insert_required(pcmd = pcmd, parameters =
 parameters, pt = pt,  :
   required parameters with no defaults missing: output
   res = super(Function, self).__call__(*new_args, **new_kwargs)
   File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/modules/vkrige.py",
 line 456, in OnPlotButton
     column = column)
   File "/usr/local/grass7/grass-7.1.svn/scripts/v.krige", line 143, in
 ImportMap
     Rpointmap = robjects.r.readVECT6(map, type =  'point')
   File "/usr/lib/python2.7/dist-packages/rpy2/robjects/functions.py", line
 178, in __call__
     return super(SignatureTranslatedFunction, self).__call__(*args,
 **kwargs)
 106, in __call__
 rpy2.rinterface.RRuntimeError: Error in insert_required(pcmd = pcmd,
 parameters = parameters, pt = pt,  :
 I am getting a similar error message when running the kriging module using
Ticket URL: <https://trac.osgeo.org/grass/ticket/2723>
