[GRASS-dev] support for raster time series in rgrass7?
Sören Gebbert soerengebbert at googlemail.com
Tue Aug 18 06:07:28 PDT 2015
Hi Veronica,
first note: the attached file is a gzip archive, the suffix is wrong.
However, this seems to be a bug in t.rast.import, since the file names
in the tar archive are listed with a "./" in the path.
I will try to fix this issue.
Best regards
Soeren
2015-08-18 14:58 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi Soeren, lists :)
> 2015-08-18 8:34 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
>> Hi Veronica,
>> can you please provide the tar.bzip2 file generated by R
> Yes, please attached the tar.bzip2 I get from R
> Thanks a lot!
> Vero
