[GRASS-dev] support for raster time series in rgrass7?
Sören Gebbert
soerengebbert at googlemail.com
Tue Aug 18 08:53:20 PDT 2015
i hopefully fixed the STRDS import so that datasets generated from R
can be imported into GRASS GIS 7.1 in r65967.
Please try this new version. I had to address several issues, but at
least i got your dataset to be correctly imported.
Best regards
Soeren
2015-08-18 15:19 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi Soeren,
> 2015-08-18 10:07 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
>> Hi Veronica,
>> first note: the attached file is a gzip archive, the suffix is wrong.
> ops! Yes, you are right... write.tgrass creates gzip files, my mistake, I'm
> sorry...
>> However, this seems to be a bug in t.rast.import, since the file names
>> in the tar archive are listed with a "./" in the path.
>> I will try to fix this issue.
> Thanks a lot!
> Vero
