[GRASS-dev] Running python test: why are they not running?
Rainer M Krug
Rainer at krugs.de
Wed Aug 19 08:02:41 PDT 2015
Hi
I am working on the homebrew script for OS X and am trying to implement
the tests. I download the test dataset, extract it, and run
--8<---------------cut here---------------start------------->8---
grass71 ./nc_basic_spm_grass7/PERMANENT --exec python -m grass.gunittest.main --location './nc_basic_spm_grass7' --location-type nc
--8<---------------cut here---------------end--------------->8---
But I get the following:
| ==> tar xzf ./nc_basic_spm_grass7.tar.gz
| ==> ls -l ./nc_basic_spm_grass7/
| total 24
| -rw-r--r-- 1 rainerkrug wheel 1035 Nov 3 2008 CREDITS.txt
| -rw-r--r-- 1 rainerkrug wheel 2710 Jul 25 2013 HISTORY.txt
| drwxr-xr-x 18 rainerkrug wheel 612 Feb 13 2013 PERMANENT
| -rw-r--r-- 1 rainerkrug wheel 130 Nov 26 2012 VERSION.txt
| drwxr-xr-- 16 rainerkrug wheel 544 Jul 25 2013 user1
| ==> grass71 ./nc_basic_spm_grass7/PERMANENT --exec python -m grass.gunittest.main --location './nc_basic_spm_grass7' --location-type nc
| WARNING: Default locale settings are missing. GRASS running with C locale.
| Starting GRASS GIS...
| Executing <python -m grass.gunittest.main --location ./nc_basic_spm_grass7 --location-type nc> ...
| Executed 0 test files in 0:00:00.046629.
| From them 0 files (unknown percentage) were successful and 0 files (unknown percentage) failed.
| Execution of <python -m grass.gunittest.main --location ./nc_basic_spm_grass7 --location-type nc> finished.
| Cleaning up temporary files...
| 04:57:47 ~$
If I run the same command in my home directory, where the dataset is
also installed, the tests run as expected.
Any suggestions why the tests do not run?
The data is downloaded, and extracted (see the ls -l above).
Any suggestions?
Thanks,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150819/aad2dc06/attachment.pgp>
