[GRASS-dev] Python scripts receiving input from the GRASS GUI?
Vaclav Petras
wenzeslaus at gmail.com
Wed Aug 19 09:36:24 PDT 2015
Michel, one more thing:
On Wed, Aug 19, 2015 at 9:47 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> 4. For attribute data (dbmgr), "copy and paste" the line's content can be
> enough. Same for query results. For query, the copy is implemented but the
> format might not be good for parsing. For dbmgr, the button to copy should
> be easy to add. This seems convenient enough for user.
Perhaps, you should first answer (especially to yourself :) why this
solution is not enough for you. If we would go with the "triggers" solution
we need will need anyway some rationale and example for the documentation
and this is perhaps a good place to start.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150819/7f362184/attachment.html>
