[GRASS-dev] g.gui.metadata and wxgui addons in GRASS 7.1
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Aug 20 05:41:42 PDT 2015
I just tried to install g.gui.metadata addon with limited success.
No AddOn appears under wxGUI when I run g.extension from the GUI (while e.g. raster addons do show up). Is this probably do to the path in the AddOn repo (which starts with gui and not wxGUI). All other tree elements in g.extension are equal to folder names in the repository...
So, I finally compiled g.gui.extension from source after installing the dependencies.
Now, g.gui.metadata is available, but does not start:
File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata",
line 1246, in <module>
main()
line 1240, in main
MAINFRAME = MdMainFrame()
line 88, in __init__
self.onInitEditor()
line 724, in onInitEditor
self.MdDataCatalogPanelLeft =
MdDataCatalog(self.leftPanel)
line 836, in __init__
self.InitTreeItems()
line 860, in InitTreeItems
self.initTemporalTree(location=location,
mapset=self.mapset)
line 923, in initTemporalTree
if self.itemExists(ml[2], varmapset) == False:
File
"/usr/local/grass-7.1.svn/gui/wxpython/lmgr/datacatalog.py",
line 213, in itemExists
item, cookie = self.GetFirstChild(root)
File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 5409, in
GetFirstChild
return _controls_.TreeCtrl_GetFirstChild(*args,
**kwargs)
ValueError: invalid null reference in method
'TreeCtrl_GetFirstChild', expected argument 2 of type
'wxTreeItemId const &'
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150820/0603e1a3/attachment-0001.html>
