[GRASS-dev] New Mac binaries uploaded
Anna Petrášová
kratochanna at gmail.com
Mon Aug 24 07:42:53 PDT 2015
Hi Michael,
sorry to report but the new binaries (70 and 71) don't work, the gui
doesn't open with this error. I already saw this error multiple times and
it might be enough just to make distclean and recompile or fresh svn
checkout.
GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent call
last):
File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 140, in <module>
sys.exit(main())
line 132, in main
app = GMApp(workspaceFile)
line 46, in __init__
wx.App.__init__(self, False)
File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 79, in OnInit
from lmgr.frame import GMFrame
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
line 37, in <module>
from mapdisp.frame import MapFrame
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
line 34, in <module>
from vdigit.toolbars import VDigitToolbar
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
line 30, in <module>
from iclass.digit import IClassVDigit
File
"/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't
have GDAL 1.10, but 1.11.
dyld: Library not loaded:
/Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
Referenced from:
/Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
Reason: image not found
Trace/BPT trap: 5
If you don't have time to look at it now, could you please post the GRASS
7.0.0 binary which I believe worked.
Thank you,
Anna
On Wed, Aug 12, 2015 at 6:29 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> I just uploaded new binaries for:
> GRASS 6.4.6 stable
> GRASS 7.0.1 stable
> GRASS 7.1 development
> These all run on current versions of Mac OS X 10.9 through 10.10.4
> Note that I’m using a newish version of GDAL complete (1.11 dated May 2015)
> I’ve heard that there may be problems compiling GRASS on OS X 10.11. I
> don’t know if these binaries will run under the new OS or not. However,
> this new OS version is not yet released. So problems may be worked out by
> the time it is finalized.
> For now, enjoy GRASS.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150824/01e16f7d/attachment-0001.html>
