[GRASS-dev] New Mac binaries uploaded
Anna Petrášová kratochanna at gmail.com
Mon Aug 24 08:39:42 PDT 2015
On Mon, Aug 24, 2015 at 11:31 AM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Anna,
> These work for me and at least some of my students here. So we need to
> find out why they don't work for you. I'm teaching spatial tech this fall
> and want to make sure others don't run into trouble. 7.0.1 was a completely
> fresh checkout and 7.1 was compiled after a make distclean.
> Do you have any idea what causes this error? Did you install a new gdal? I
> compiled with William's most current version. I am still using stock Mac
> Python and wx version 2.8.12. Have you installed anything newer in the
> testing I saw on the list?
I did install the newest GDAL 1.11 and I was testing the homebrew
installation, but it should have everything separate. Helena had the same
problem, so it's not just me. Weird. Some students will try to install it
so I will let you know if they have problems or not.
> Michael Barton
> School of Human Evolution &Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> ...Sent from my iPad
> On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi Michael,
> sorry to report but the new binaries (70 and 71) don't work, the gui
> doesn't open with this error. I already saw this error multiple times and
> it might be enough just to make distclean and recompile or fresh svn
> checkout.
> GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent
> call last):
>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py",
> line 140, in <module>
>     sys.exit(main())
> line 132, in main
>     app = GMApp(workspaceFile)
> line 46, in __init__
>     wx.App.__init__(self, False)
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line
> 7981, in __init__
>     self._BootstrapApp()
>   File
> 7555, in _BootstrapApp
>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
> line 79, in OnInit
>     from lmgr.frame import GMFrame
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> line 50, in <module>
>     from lmgr.layertree        import LayerTree, LMIcons
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
> line 37, in <module>
>     from mapdisp.frame        import MapFrame
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
> line 34, in <module>
>     from vdigit.toolbars    import VDigitToolbar
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
> line 30, in <module>
>     from iclass.digit       import IClassVDigit
>   File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
> line 23, in <module>
>     from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
> ImportError: cannot import name TYPE_AREA
> Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't
> have GDAL 1.10, but 1.11.
> dyld: Library not loaded:
> /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
>   Referenced from:
> /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
>   Reason: image not found
> Trace/BPT trap: 5
> If you don't have time to look at it now, could you please post the GRASS
> 7.0.0 binary which I believe worked.
> Thank you,
> Anna
> On Wed, Aug 12, 2015 at 6:29 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> I just uploaded new binaries for:
>> GRASS 6.4.6 stable
>> GRASS 7.0.1 stable
>> GRASS 7.1 development
>> These all run on current versions of Mac OS X 10.9 through 10.10.4
>> Note that I’m using a newish version of GDAL complete (1.11 dated May
>> 2015)
>> I’ve heard that there may be problems compiling GRASS on OS X 10.11. I
>> don’t know if these binaries will run under the new OS or not. However,
>> this new OS version is not yet released. So problems may be worked out by
>> the time it is finalized.
>> For now, enjoy GRASS.
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Head, Graduate Faculty in Complex Adaptive Systems Science
>> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150824/51a54a87/attachment.html>
