[GRASS-dev] [GRASS GIS] #513: g.rename extremely slow, speed improvement
GRASS GIS trac at osgeo.org
Mon Aug 24 15:34:28 PDT 2015
  Reporter:  gisboa       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  minor        |  Milestone:  6.4.0
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  vector database rename
       CPU:  All          |   Platform:  All
Comment (by glynn):
 Replying to [comment:1 glynn]:
 > Suggestion 1: drop support for the DBF driver. Its presence means that
 everything that uses the DBMI has to limit itself to the tiny subset of
 SQL which the DBF driver actually understands (e.g.: no joins), often
 having to adopt inefficient workarounds.
 +1
 > Suggestion 3: upgrade the DBF driver so that it supports at least the
 basic features of SQL, e.g. joins.
 This is far from straightforward. You'd need to write a query optimiser,
 and you'd need to maintain indices. Ultimately, efficient implementation
 of joins is the heart of any RDBMS.
 Extending it to support isolated features such as renaming tables or
 columns probably wouldn't be particularly hard, although it's debatable
 whether there's any point given that the lack of support for joins makes
 it inferior to SQLite in every regard.
Ticket URL: <https://trac.osgeo.org/grass/ticket/513#comment:3>
