[GRASS-dev] g.gui.metadata and wxgui addons in GRASS 7.1
Matej Krejci matejkrejci at gmail.com
Mon Aug 24 23:38:44 PDT 2015
Hi Stephan,
2015-08-21 22:08 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath na nina.no>:
> Hi Matej,
> I just checked out your new revision. Now I get on sudo make
> MODULE_TOPDIR=/usr/local/grass-7.1.svn/:
> make[1]: Entering directory
> `/data/src/grass7_addons/gui/wxpython/wx.metadata/g.gui.metadata'
> if [ "/usr/local/grass-7.1.svn/scripts/g.gui.metadata" != "" ] ; then
> GISRC=/usr/local/grass-7.1.svn/demolocation/.grassrc71
> GISBASE=/usr/local/grass-7.1.svn
> PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:$PATH"
> PYTHONPATH="/usr/local/grass-7.1.svn/etc/python:/usr/local/grass-7.1.svn/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:/usr/local/grass-7.1.svn/lib:/usr/local/grass-7.1.svn/lib:"
> LC_ALL=C /usr/local/grass-7.1.svn/scripts/g.gui.metadata --html-description
> < /dev/null | grep -v '</body>\|</html>' > g.gui.metadata.tmp.html ; fi
> Traceback (most recent call last):
>   File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata", line 27, in
> <module>
>     sys.path.insert(2, os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc',
> 'wx.metadata', 'mdlib'))
>   File "/usr/lib/python2.7/posixpath.py", line 77, in join
>     elif path == '' or path.endswith('/'):
> AttributeError: 'NoneType' object has no attribute 'endswith'
> make[1]: *** [g.gui.metadata.tmp.html] Error 1
> rm g.gui.metadata.tmp.html
> make[1]: Leaving directory
Problem was that I never try *make* with *sudo*. I am not sure why it has
effect. Problem should be fixed in r66007.
thank you for testing
Best
Matej
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150825/4a0b5541/attachment.html>
