[GRASS-dev] PyGRASS API changes and test update
Sören Gebbert soerengebbert at googlemail.com
Tue Aug 25 01:28:44 PDT 2015
Dear all,
just to inform you:
I plan to commit this week a larger update to PyGRASS vector implementation.
This will include API changes to harmonize the method names and calls
(removing unnecessary "get_" method prefix or renaming it to "to_"
[get_wkt -> to_wkt, ...]).
I will update many doctests and implement unittests that will use a
on-the-fly generated test vector instead of vector maps from
NC/spearfish location.
I will modify the vector attribute handling, so that categories are
not generated by default in increasing order, but must be provided by
the user.
Best regards
Soeren
