[GRASS-dev] proposal for g.search module
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Dec 1 00:53:48 PST 2015
renamed g.search.module -> g.search.modules
po 30. 11. 2015 v 22:33 odesÃlatel Vaclav Petras <wenzeslaus at gmail.com>
napsal:
> On Mon, Nov 30, 2015 at 4:22 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> > Considering the fact that an important/main use case is interactive
>> usage in
>> > the command line, I now lean towards:
>> > g.search.module aspect
>> I would suggest to not use the singular "module" but plural "modules"
>> which would better explain itself.
>> We are searching in multiple modules, aren't we?
>> So my suggestion:
>> g.search.modules
> Right! We are also getting multiple modules as a result. The GUI tab is
> called Search modules, I've mentioned here myself but then forgot about it.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151201/170ff39c/attachment-0001.html>
