[GRASS-dev] error in interactive supervised classification input - update
Michael Barton
Michael.Barton at asu.edu
Tue Dec 1 14:55:34 PST 2015
Apparently no graphs work in the interactive iclass module. Also, it doesn’t seem to work otherwise.
I can mark training fields with no problem. I can export them with no problem.
But when I click the update button, the preview screen goes blank for a bit for each class then returns to the original base raster with nothing showing. The command console displays the following errors (one for each class):
Data error preparing signatures: value (19592) > num of cats
(256)
Data error preparing signatures: value (8089) > num of cats
(256)
Data error preparing signatures: value (11048) > num of cats
(256)
Data error preparing signatures: value (9218) > num of cats
(256)
I’ve looked at the very slim help file and it did not help. Copying Helena and Anna in case they’ve be successful with this working.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 1, 2015, at 3:33 PM, Michael Barton <michael.barton at ASU.Edu<mailto:michael.barton at ASU.Edu>> wrote:
When I try to use g.gui.iclass, I get the error in the attached file. It says it was unable to import matplotlib. Then it says it did find matplotlib but it was the wrong architecture.
If I fire up Python from the GRASS terminal and import matplotlib, it is fine. I also tried to install matplotlib from the terminal in case it would find a correct architecture version. This also went fine.
So I begin to suspect that this is a bug instead of a problem with my systems. Any thoughts?
Mac OS X 10.10.3
GRASS 7.0.2, compliled a week ago.
Michael
[cid:EEFBA06D-DD02-4EC1-8838-38E1C18E9BD1 at dhcp.asu.edu]
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151201/0df06626/attachment-0001.html>
Type: image/png
Desc: error.png
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151201/0df06626/attachment-0001.png>
