[GRASS-dev] Unable to rename cell/null file - NULL file messed up
Glynn Clements
glynn at gclements.plus.com
Wed Dec 2 20:15:23 PST 2015
Paulo van Breugel wrote:
> Can't answer that, but I see that a related (?) ticket
#2434 isn't related to #2712. #2712 relates specifically to the null
file compression changes. #2434 was opened a year before those changes
were started.
> https://trac.osgeo.org/grass/ticket/2434 was retargeted to 7.03? From the
> description that issue seems to be very similar to the problem described
> above?
The problem described above:
> > > WARNING: Unable to rename cell file
> > > 'C:\GIS\GrassJvdS/latlong/YLD_NUT/.tmp/unknown/3988.0' to
> > > 'C:\GIS\GrassJvdS/latlong/YLD_NUT/fcell/Shan3_CA_Renyi_0_0': File exists
> > > WARNING: Unable to rename null file
> > > 'C:\GIS\GrassJvdS/latlong_2005/YLD_NUT/.tmp/unknown/4100.1' to
> > > 'C:\GIS\GrassJvdS/latlong_2005/YLD_NUT/cell_misc/Shan3_CA_Renyi_1_0/null':
> > > File exists
doesn't match the symptoms of either #2434 or #2712. In both of those
cases, the rename() fails with EACCESS ("Permission denied"), which is
symptomatic of the file being open.
This case fails with EEXIST ("File exists"), which suggests that the
destination file wasn't deleted first. On Unix, deleting the original
isn't required (or even desired); rename() will atomically remove any
existing file. Windows generates an error if the destination exists.
So we (try to) remove it first (on all platforms).
remove(path);
if (rename(fcb->temp_name, path)) {
G_warning(_("Unable to rename cell file '%s' to '%s': %s"),
fcb->temp_name, path, strerror(errno));
stat = -1;
(close_new() in lib/raster/close.c).
The warning suggests that the file exists and remove() failed to
remove it. On Windows, that can happen if the file is open.
And looking at r.biodiversity.py, I notice:
grass.mapcalc("$outl = -1 * $outl",
outl=out_renyi,
overwrite=True,
quiet=True)
I.e. it's running r.mapcalc with the same map as both input and
output. That isn't guaranteed to work. And in fact it doesn't, because
the close_maps() function (which closes all of the input maps) is
never actually called.
So when it tries to close the output maps, which involves renaming the
new cell/fcell/null files into place, the original cell/fcell/null
files are still open for reading, meaning that the remove() will fail,
as will the subsequent rename().
Having r.mapcalc close the input maps would avoid that, and should be
done, but ultimately that's fixing the symptoms. r.biodiversity
shouldn't be trying to modify out_renyi "in-place". It should create a
new map then, if necessary, replace the original using g.remove and
g.rename.
One problem with in-place modification is that closing an output map
writes a number of support files (history, range, quant, cats,
histogram). But after closing the output maps, r.mapcalc will
sometimes copy some of the metadata (cats, colors, history) from the
input map. Currently, it only does this if the entire expression is
just a map with optional modifiers, but it may get more "intelligent"
in the future. Clearly, that's a problem if the input map has already
been replaced.
