[GRASS-dev] error in interactive supervised classification input - update
Anna Petrášová kratochanna at gmail.com
Thu Dec 3 00:49:38 PST 2015
On Dec 2, 2015 10:59 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
> It is landsat 8, which is 16 bit. So that may account for one issue. If
so, the error about matplotlib is a 2nd issue.
Yes, I remember having problems with matplotlib before on Mac, it's all
related to the 32-bit wxpython I think
Anna
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Dec 2, 2015, at 8:20 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
>> Is it landsat 8? g.gui.iclass is rewritten i.class which supported only
256 categories...
>> On Tue, Dec 1, 2015 at 5:55 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
>>> Apparently no graphs work in the interactive iclass module. Also, it
doesn’t seem to work otherwise.
>>> I can mark training fields with no problem. I can export them with no
problem.
>>> But when I click the update button, the preview screen goes blank for a
bit for each class then returns to the original base raster with nothing
showing. The command console displays the following errors (one for each
class):
>>> Data error preparing signatures: value (19592) > num of cats
>>> (256)
>>> Data error preparing signatures: value (8089) > num of cats
>>> (256)
>>> Data error preparing signatures: value (11048) > num of cats
>>> (256)
>>> Data error preparing signatures: value (9218) > num of cats
>>> (256)
>>> I’ve looked at the very slim help file and it did not help. Copying
Helena and Anna in case they’ve be successful with this working.
>>> Michael
>>> C. Michael Barton
>>>> On Dec 1, 2015, at 3:33 PM, Michael Barton <michael.barton at ASU.Edu>
wrote:
>>>> When I try to use g.gui.iclass, I get the error in the attached file.
It says it was unable to import matplotlib. Then it says it did find
matplotlib but it was the wrong architecture.
>>>> If I fire up Python from the GRASS terminal and import matplotlib, it
is fine. I also tried to install matplotlib from the terminal in case it
would find a correct architecture version. This also went fine.
>>>> So I begin to suspect that this is a bug instead of a problem with my
systems. Any thoughts?
>>>> Mac OS X 10.10.3
>>>> GRASS 7.0.2, compliled a week ago.
>>>> Michael
>>>> <error.png>
>>>> C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151203/f46b4aa2/attachment.html>
