[GRASS-dev] WARNING TO MAC USERS - WAIT UPDATING TO EL CAPITAN (OS X 10.11)
Benjamin Ducke benducke at fastmail.fm
Sat Dec 5 02:58:35 PST 2015
On 04/12/15 21:51, William Kyngesburye wrote:
> My thought is that it's a packaging problem.
> As it is, the GRASS source should run on El Cap, with a simple
> configure-make-install and no packaging.  It will use external
> libraries in their installed locations, which should work in El Cap.
> The problem comes when some of those external libraries are bundled
> inside the app without any modification (ie wxPython).  Those
> libraries still have their embedded install locations which would
> normally break other software (and is not related to the El Capitan
> problem), but GRASS sets DYLD_LIBRARY_PATH to get around this (I
> don't know the original reason for this, but it makes the package
> moveable/renamable).  DYLD_LIBRARY_PATH is where the El Cap problem
> comes in - as part of new security features the system now ignores
> this.
The situation seems a litte more complex.
Apparently, DYLD_LIBRARY_PATH is not always ignored;
but it cannot be inherited by subprocesses if the latter
are spawned by programs that are deemed integral to system
security.
There is a very informative discussion about this
issue on the PostgreSQL mailing list:
http://www.postgresql.org/message-id/561E73AB.8060800@gmx.net
Note in particular this reply, which sheds some light
on the effects of SIP on system programs like
"sh" and "python":
http://www.postgresql.org/message-id/CAB7nPqSVgbf4kX6=L-pd9GjJ3O_VLSxuoPA6LML6JoiF+HP-Mg@mail.gmail.com
> 2 possible solutions, both on the packaging end:
As a third alternative:
It is still possible (wonder for how much longer?)
to disable SIP and make DYLD_LIBRARY_PATH work
as expected on El Capitan.
Best,
Ben
> - compile the external libraries (before compiling GRASS) as if they
> are embedded in the GRASS app.  That is, configure the prefix to be
> inside the to-be-installed GRASS app.
> - post-process the libraries when bundled to update the embedded
> library paths.
> The first is simple, but has a couple drawbacks: the app is not
> moveable (minor) because it still depends on the full paths embedded
> in the libraries and GRASS, and this doesn't work with premade
> binaries of the libraries (like wxPython).
> The second is harder, but can be done to any bundled library or tool,
> and the paths can be made relative to make the app movable/renamable.
> Though the movablility part would be best supplemented by changes in
> the GRASS source makefiles to make GRASS have all relative paths
> (this is what I was originally looking at, that stalled me).
> At a minimum, and the simplest, full paths should be changed in the
> bundled external libraries, by either or both methods.
>> On Dec 4, 2015, at 2:09 PM, Brian Miles <selimnairb at gmail.com>
>> wrote:
>> Michael, William,
>> I'd like to take a look at this to see if I can help.  I'm not an
>> expert in makefiles, or linkers, but I'm willing to put some time
>> in to help move the ball forward.  Is there a synopsis of the
>> problem so I don't have to start from square one?
>> Thanks,
>> Brian
>>> On Dec 4, 2015, at 2:47 PM, Michael Barton
>>> <Michael.Barton at asu.edu> wrote:
>>> This is still not resolved. William Kyngesburye has suggested
>>> some ways forward, but we are not yet sure exactly what causes
>>> the failure. Help is appreciated.
>>> Michael ____________________ C. Michael Barton Director, Center
>>> for Social Dynamics & Complexity Professor of Anthropology,
>>> School of Human Evolution & Social Change Head, Graduate Faculty
>>> in Complex Adaptive Systems Science Arizona State University
>>> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC) fax:
>>> 480-965-7671 (SHESC),  480-727-0709 (CSDC) www:
>>> http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>>> On Dec 4, 2015, at 12:36 PM, Brian Miles <selimnairb at gmail.com>
>>>> wrote:
>>>> Michael,
>>>> Just wondering what the status is on this.  Is there a ticket
>>>> describing the problems with OS X 10.11 and GRASS, and
>>>> hopefully tracking the progress to a fix?  I tried searching
>>>> the tickets (http://trac.osgeo.org/grass/), but wasn't able to
>>>> filter out enough false positives.
>>>> Thanks,
>>>> Brian Miles Research Scientist Institute for the Environment
>>>> University of North Carolina at Chapel Hill
>>>>> On Oct 8, 2015, at 8:14 PM, grass-dev-request at lists.osgeo.org
>>>>> wrote:
>>>>> From: Michael Barton <Michael.Barton at asu.edu> Date: October
>>>>> 8, 2015 at 8:07:58 PM EDT To: GRASS developers
>>>>> grass-developers <grass-dev at lists.osgeo.org>, "grass-user
>>>>> grass-user" <grass-user at lists.osgeo.org> Subject: [GRASS-dev]
>>>>> 10.11)
>>>>> I've had reports of GRASS not running for users updating to
>>>>> El Capitan. There is a possible workaround, but it is
>>>>> cumbersome and not guaranteed to work. I recommend that you
>>>>> do wait to update while we try to solve this.
>>>>> I've also heard that El Capitan breaks R.
>>>>> Center for Social Dynamics & Complexity Professor of
>>>>> Anthropology, School of Human Evolution & Social Change Head,
>>>>> Graduate Faculty in Complex Adaptive Systems Science Arizona
>>>>> State University
>>>>> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC) www:
> ----- William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> _______________________________________________ grass-dev mailing
> list grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
