[GRASS-dev] Change name addon
Paulo van Breugel p.vanbreugel at gmail.com
Wed Dec 9 06:25:19 PST 2015
On Wed, Dec 9, 2015 at 10:59 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi Markus,
> Sorry for the mess, and thanks for your help. There is no svn mv on the
> SVN howto. But in any case, the script/html/make files are already copied
> and renamed to a new folder r.series.diversity. So from what I understand
> can I delete the old folder and content using from the command line?
> cd /home/paulo/Software/spatial/grass-addons/
> update svn
> cd raster
> svn rm r.biodiversity' (being in the raster folder
Tried it again and this time removing the folder worked. Not sure why it
didn't work the other time.
> I am not sure what you mean with 'make clean'? Is this what updates the
> makefile in the raster directory, or should the list of addons in that
> makefile be updated manually? (on a somewhat related note, I see that the
> list of addons in that makefile is not complete, e.g., r.series.decompose
> is missing).
> Paulo
> On Wed, Dec 9, 2015 at 10:39 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Dec 9, 2015 10:32 AM, "Paulo van Breugel" <p.vanbreugel at gmail.com>
>> wrote:
>> > Hi, I tried to rename the r.biodiversity addon to r.series.diversity
>> (because this better reflects what it does and better distinguishes it from
>> r.diversity). Seems I did something wrong because the old folder
>> r.biodiversity is still there in the svn. Sorry for that. Before I mess
>> things up even more, any pointer how to solve this?
>> In trac you find a SVN howto.
>> Check for 'svn mv ...'
>> Be sure to have run
>> make clean
>> before.
I am not sure where to run this make clean, and whether I should manually
update the makefile in the raster folder to delete the r.biodiversity and
add the r.series.diversity to the list.
Hopefully not related, but I noticed that the build status of many of the
addons is 'failed' (https://grass.osgeo.org/addons/grass7/logs/index.html)
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151209/14219549/attachment-0001.html>
