[GRASS-dev] Fwd: New Defects reported by Coverity Scan for grass
Markus Neteler neteler at osgeo.org
Fri Dec 11 04:30:32 PST 2015
FYI - from a yesterday's run.
BTW: we should connect it to Travis:
https://scan.coverity.com/travis_ci
---------- Forwarded message ----------
Date: Thu, Dec 10, 2015 at 4:47 PM
Subject: New Defects reported by Coverity Scan for grass
Please find the latest report on new defect(s) introduced to grass
found with Coverity Scan.
37 new defect(s) introduced to grass found with Coverity Scan.
65 defect(s), reported by Coverity Scan earlier, were marked fixed in
the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 20 of 37 defect(s)
** CID 1208403:    (TAINTED_SCALAR)
/lib/vector/Vlib/open_ogr.c: 306 in Vect_open_fidx()
________________________________________________________________________________________________________
*** CID 1208403:    (TAINTED_SCALAR)
300         /* number of records  */
301         if (0 >= dig__fread_port_I(&(offset->array_num), 1, &fp))
302             return -1;
303
304         /* alloc space */
305         offset->array = (int *) G_malloc(offset->array_num * sizeof(int));
>>>     Assigning: "offset->array_alloc" = "offset->array_num". Both are now tainted.
306         offset->array_alloc = offset->array_num;
307
308         /* offsets */
309         if (0 >= dig__fread_port_I(offset->array,
310                                    offset->array_num, &fp))
311             return -1;
/lib/vector/Vlib/open_ogr.c: 305 in Vect_open_fidx()
299
302             return -1;
303
>>>     Passing tainted variable "offset->array_num * 4UL" to a tainted sink.
307
308         /* offsets */
** CID 1341810:  Uninitialized variables  (UNINIT)
/vector/v.out.lidar/main.c: 200 in get_integer_column_value()
*** CID 1341810:  Uninitialized variables  (UNINIT)
194             val = catval->val.i;
195         }
196         else if (column_values->ctype == DB_C_TYPE_DOUBLE) {
197             val = catval->val.d;
198         }
199         /* else should be checked by caller */
>>>     Using uninitialized value "val".
200         return val;
201     }
202
203     /*! Get RGB in a column for a category as three integers
204      *
205      * Expects the column to be a string.
** CID 1341811:  Memory - corruptions  (STRING_SIZE)
/lib/iostream/ami_stream.cpp: 86 in ami_single_temp_name(const
std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char>> &, char *)()
*** CID 1341811:  Memory - corruptions  (STRING_SIZE)
80       base_dir = getenv(STREAM_TMPDIR);
81       if(!base_dir) {
82      fprintf(stderr, "ami_stream: %s not set\n", STREAM_TMPDIR);
83      assert(base_dir);
84      exit(1);
85       }
>>>     Passing string "base_dir" of unknown size to "sprintf".
86       sprintf(tmp_path, "%s/%s_XXXXXX", base_dir, base.c_str());
87
88       fd = G_mkstemp(tmp_path, O_RDWR, 0600);
89
90       if (fd == -1) {
91         cerr <<  "ami_single_temp_name: ";
** CID 1341812:  Memory - corruptions  (STRING_SIZE)
/lib/gis/file_name.c: 89 in G_file_name_tmp()
*** CID 1341812:  Memory - corruptions  (STRING_SIZE)
83     {
84         const char *env, *tmp_path;
85
86         tmp_path = NULL;
87         env = getenv("GRASS_VECTOR_TMPDIR_MAPSET");
88         if (env && strcmp(env, "0") == 0) {
>>>     Assigning: "tmp_path" = "getenv". "tmp_path" is now tainted.
89             tmp_path = getenv("TMPDIR");
90         }
91
92         return file_name(path, NULL, element, name, mapset, tmp_path);
93     }
94
** CID 1341813:    (STRING_OVERFLOW)
/raster/r.in.lidar/projection.c: 33 in projection_mismatch_report()
/raster/r.in.lidar/projection.c: 40 in projection_mismatch_report()
/raster/r.in.lidar/projection.c: 49 in projection_mismatch_report()
/raster/r.in.lidar/projection.c: 55 in projection_mismatch_report()
/raster/r.in.lidar/projection.c: 94 in projection_mismatch_report()
*** CID 1341813:    (STRING_OVERFLOW)
27                                     struct Key_Value *proj_info,
28                                     struct Key_Value *proj_units, int err)
29     {
30         int i_value;
31         char error_msg[8192];
32
>>>     You might overrun the 8192 byte fixed-size string "error_msg" by copying the return value of "G_gettext" without checking the length.
33         strcpy(error_msg,
34                _("Projection of dataset does not"
35                  " appear to match current location.\n\n"));
36
37         /* TODO: output this info sorted by key: */
38         if (loc_wind.proj != cellhd.proj || err != -2) {
36
39             if (loc_proj_info != NULL) {
40                 strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
41                 for (i_value = 0; i_value < loc_proj_info->nitems; i_value++)
42                     sprintf(error_msg + strlen(error_msg), "%s: %s\n",
43                             loc_proj_info->key[i_value],
44                             loc_proj_info->value[i_value]);
45                 strcat(error_msg, "\n");
46             }
47
48             if (proj_info != NULL) {
49                 strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
50                 for (i_value = 0; i_value < proj_info->nitems; i_value++)
51                     sprintf(error_msg + strlen(error_msg), "%s: %s\n",
52                             proj_info->key[i_value],
53             }
54             else {
53             }
54             else {
55                 strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
56                 if (cellhd.proj == PROJECTION_XY)
57                     sprintf(error_msg + strlen(error_msg),
58                             "Dataset proj = %d (unreferenced/unknown)\n",
59                             cellhd.proj);
60                 else if (cellhd.proj == PROJECTION_LL)
88             }
89         }
90         sprintf(error_msg + strlen(error_msg),
91                 _("\nIn case of no significant differences in the
projection definitions,"
92                  " use the -o flag to ignore them and use"
93                  " current location definition.\n"));
94         strcat(error_msg,
95                _("Consider generating a new location with
'location' parameter"
96                  " from input data set.\n"));
97         G_fatal_error("%s", error_msg);
98     }
99
** CID 1341814:  Incorrect expression  (SIZEOF_MISMATCH)
/vector/v.decimate/grid_decimation.c: 25 in grid_decimation_create()
*** CID 1341814:  Incorrect expression  (SIZEOF_MISMATCH)
19
20     /* max size: rows * cols < max of size_t (using 1D array) */
21     void grid_decimation_create(struct GridDecimation *grid_decimation,
22                                 size_t rows, size_t cols)
23     {
24         grid_decimation->grid_points =
>>>     Passing argument "8UL /* sizeof (struct DecimationPoint *) */" to function "G__calloc" and then casting the return value to "struct DecimationPoint ***" is suspicious.
25             G_calloc(rows * cols, sizeof(struct DecimationPoint *));
26         grid_decimation->grid_sizes = G_calloc(rows * cols, sizeof(size_t));
27         grid_decimation->rows = rows;
28         grid_decimation->cols = cols;
29         grid_decimation->if_add_point = NULL;
30         grid_decimation->on_add_point = NULL;
** CID 1341815:  Null pointer dereferences  (REVERSE_INULL)
/lib/db/dbmi_base/login.c: 318 in get_login()
*** CID 1341815:  Null pointer dereferences  (REVERSE_INULL)
312
313                 if (login.data[i].host &&
strlen(login.data[i].host) > 0 && host)
314                     *host = G_store(login.data[i].host);
315                 else
316                     *host = NULL;
317
>>>     Null-checking "port" suggests that it may be null, but it has already been dereferenced on all paths leading to the check.
318                 if (login.data[i].port &&
strlen(login.data[i].port) > 0 && port)
319                     *port = G_store(login.data[i].port);
320                 else
321                     *port = NULL;
322
323                 break;
** CID 1341816:  Null pointer dereferences  (REVERSE_INULL)
/lib/db/dbmi_base/login.c: 313 in get_login()
*** CID 1341816:  Null pointer dereferences  (REVERSE_INULL)
307
308                 if (login.data[i].password &&
strlen(login.data[i].password) > 0)
309                     *password = G_store(login.data[i].password);
310                 else
311                     *password = NULL;
312
>>>     Null-checking "host" suggests that it may be null, but it has already been dereferenced on all paths leading to the check.
315                 else
316                     *host = NULL;
317
** CID 1341817:    (RESOURCE_LEAK)
/lib/vector/Vlib/close_nat.c: 158 in V1_close_nat()
/lib/vector/Vlib/close_nat.c: 171 in V1_close_nat()
*** CID 1341817:    (RESOURCE_LEAK)
152
153                     /* drop also attribute table */
154                     ndblinks = Vect_get_num_dblinks(Map);
155                     for (i = 0; i < ndblinks; i++) {
156                         fi = Vect_get_dblink(Map, i);
157
>>>     Overwriting "driver" in "driver = db_start_driver_open_database(fi->driver, fi->database)" leaks the storage that "driver" points to.
158                         driver =
db_start_driver_open_database(fi->driver, fi->database);
159                         if (driver == NULL) {
160                             G_warning(_("Unable to open database
<%s> by driver <%s>"),
161                                       fi->database, fi->driver);
162                             continue;
163                         }
165                         db_set_string(&table_name, fi->table);
166                         if (DB_OK != db_drop_table(driver, &table_name)) {
167                             G_warning(_("Unable to drop table
<%s>"), fi->table);
168                             continue;
169                         }
170                     }
>>>     Variable "driver" going out of scope leaks the storage it points to.
171                 }
172     #endif
173             }
174         }
175
176         return 0;
** CID 1341818:    (RESOURCE_LEAK)
/lib/vector/Vlib/close_nat.c: 156 in V1_close_nat()
*** CID 1341818:    (RESOURCE_LEAK)
150
151                     db_init_string(&table_name);
152
>>>     Overwriting "fi" in "fi = Vect_get_dblink(Map, i)" leaks the storage that "fi" points to.
157
158                         driver =
<%s>"), fi->table);
168                             continue;
169                         }
170                     }
>>>     Variable "fi" going out of scope leaks the storage it points to.
171                 }
172     #endif
173             }
174         }
175
176         return 0;
** CID 1341819:  Resource leaks  (RESOURCE_LEAK)
/raster/r.in.lidar/projection.c: 142 in projection_check_wkt()
*** CID 1341819:  Resource leaks  (RESOURCE_LEAK)
136                                        proj_info, proj_units, err);
137         }
138         else if (verbose) {
139             G_message(_("Projection of input dataset and current location "
140                         "appear to match"));
141         }
>>>     Variable "proj_units" going out of scope leaks the storage it points to.
** CID 1341820:  Resource leaks  (RESOURCE_LEAK)
*** CID 1341820:  Resource leaks  (RESOURCE_LEAK)
137         }
141         }
>>>     Variable "proj_info" going out of scope leaks the storage it points to.
** CID 1341821:  Resource leaks  (RESOURCE_LEAK)
*** CID 1341821:  Resource leaks  (RESOURCE_LEAK)
137         }
141         }
>>>     Variable "loc_proj_units" going out of scope leaks the storage it points to.
** CID 1341822:  Resource leaks  (RESOURCE_LEAK)
*** CID 1341822:  Resource leaks  (RESOURCE_LEAK)
137         }
141         }
>>>     Variable "loc_proj_info" going out of scope leaks the storage it points to.
** CID 1341823:  Resource leaks  (RESOURCE_LEAK)
/raster/r.in.lidar/rast_segment.c: 37 in rast_segment_open()
*** CID 1341823:  Resource leaks  (RESOURCE_LEAK)
31         int segment_rows = 64;
32
33         /* we use long segments because this is how the values a binned */
34         int segment_cols = Rast_input_window_cols();
35         int segments_in_memory = 4;
36
>>>     Failing to save or free storage allocated by "G_tempfile()" leaks it.
37         if (Segment_open(segment, G_tempfile(), Rast_input_window_rows(),
38                          Rast_input_window_cols(), segment_rows,
segment_cols,
39                          Rast_cell_size(*map_type), segments_in_memory) != 1)
40             G_fatal_error(_("Cannot create temporary file with
segments of a raster map"));
41         rast_segment_load(segment, rowio, *map_type);
42         Rast_close(rowio);          /* we won't need the raster again */
** CID 1341824:  Resource leaks  (RESOURCE_LEAK)
/raster/r.in.lidar/rast_segment.c: 20 in rast_segment_load()
*** CID 1341824:  Resource leaks  (RESOURCE_LEAK)
14
15         for (row = 0; row < Rast_input_window_rows(); row++) {
16             /* TODO: free mem */
17             Rast_get_row(rowio, raster_row, row, map_type);
18             Segment_put_row(segment, raster_row, row);
19         }
>>>     Variable "raster_row" going out of scope leaks the storage it points to.
20     }
21
22     /* TODO: close function */
23
24     void rast_segment_open(SEGMENT * segment, const char *name,
25                            RASTER_MAP_TYPE * map_type)
** CID 1341825:    (RESOURCE_LEAK)
/lib/db/dbmi_client/copy_tab.c: 203 in copy_table()
*** CID 1341825:    (RESOURCE_LEAK)
197
198                 if (ret != DB_OK) {
199                     db_close_database_shutdown_driver(to_driver);
200                     if (from_driver != to_driver)
201                         db_close_database_shutdown_driver(from_driver);
202
>>>     Variable "tblname_i" going out of scope leaks the storage it points to.
203                     return DB_FAILED;
204                 }
205             }
206
207             G_free(tblname_i);
208         }
197
202
204                 }
205             }
206
208         }
** CID 1341826:  API usage errors  (PW.TOO_MANY_PRINTF_ARGS)
/vector/v.in.lidar/main.c: 635 in ()
*** CID 1341826:  API usage errors  (PW.TOO_MANY_PRINTF_ARGS)
629                     }
630                 }
631                 sprintf(error_msg + strlen(error_msg),
632                         _("\nIn case of no significant differences
in the projection definitions,"
633                           " use the -o flag to ignore them and use"
634                           " current location definition.\n"),
>>>     the format string ends before this argument
635                         G_program_name());
636                 strcat(error_msg,
637                        _("Consider generating a new location with
638                         " from input data set.\n"));
639                 G_fatal_error("%s", error_msg);
640             }
** CID 1341827:  API usage errors  (PW.TOO_MANY_PRINTF_ARGS)
/raster3d/r3.info/main.c: 485 in ()
*** CID 1341827:  API usage errors  (PW.TOO_MANY_PRINTF_ARGS)
479                     fprintf(out, "\"%s\"\n",
Rast_get_history(&hist, HIST_DATSRC_1));
480                     fprintf(out, "source2=");
481                     fprintf(out, "\"%s\"\n",
Rast_get_history(&hist, HIST_DATSRC_2));
482                     fprintf(out, "description=");
483                     fprintf(out, "\"%s\"\n",
Rast_get_history(&hist, HIST_KEYWRD));
484                     if (Rast_history_length(&hist)) {
485                         fprintf(out, "comments=\"", i);
486                         for (i = 0; i < Rast_history_length(&hist); i++)
487                             fprintf(out, "%s", Rast_history_line(&hist, i));
488                         fprintf(out, "\"\n");
489                     }
490                 }
** CID 1341828:  API usage errors  (PW.PRINTF_ARG_MISMATCH)
/vector/v.random/main.c: 577 in ()
*** CID 1341828:  API usage errors  (PW.PRINTF_ARG_MISMATCH)
571                 if (flag.z->answer)
572                     Vect_append_point(Points, x, y, z);
573                 else
574                     Vect_append_point(Points, x, y, 0.0);
575
576                 if (parm.zcol->answer) {
>>>     argument is incompatible with corresponding format string conversion
577                     sprintf(buf, "insert into %s values ( %d, ",
Fi->table, i + 1);
578                     db_set_string(&sql, buf);
579                     /* Round random value if column is integer type */
580                     if (usefloat)
581                         sprintf(buf, "%f )", z);
582                     else
To view the defects in Coverity Scan visit,
https://scan.coverity.com/projects/grass?tab=overview
