[GRASS-dev] [GRASS GIS] #2824: g.gui.timeline throws exception when trying to display temporal dataset.
trac at osgeo.org
Fri Dec 11 14:11:52 PST 2015
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.1
Resolution: | Keywords: g.gui.timeline
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
[http://stackoverflow.com/questions/32788554/plotting-with-date-times-and-
matplotlib Comment on a SO answer says]:
> It sounds like you're calling `date2num` on a `float`. `date2num`
expects `datetime` objects. ...appears to already be in exactly the format
that `date2num` would be converting it do. Replace `date2num(time)` with
just `time`...
But I'm not sure if this applies in this case. That one was related to
some particular NetCDF file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:1>
