[GRASS-dev] [GRASS GIS] #2826: wxGUI: encoding issues
GRASS GIS trac at osgeo.org
Tue Dec 15 05:40:05 PST 2015
 Reporter:  mlennert     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.3
Component:  wxGUI        |    Version:  7.0.2
 Keywords:  encoding     |        CPU:  Unspecified
 Platform:  Unspecified  |
 I'm getting bitten by quite a lot of encoding issues in the wxGUI lately.
 I'm putting them here into one bug report as they all seem to have a
 similar pattern, but I can split up into separate bug reports if
 necessary.
 Here are two examples using freshly checked out trunk (but I can reproduce
 in grass70_release and in grass 7.0.2 - all with locale fr_BE.utf8):
 * v.to.rast/r.to.vect: just launching the module makes three error windows
 pop up with "'ascii' codec can't decode byte 0xc3 in position 8: ordinal
 not in range(128)". After clicking through the three messages, I can
 launch the command. In the console I get:
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
 -unknown-linux-gnu/gui/wxpython/gui_core/forms.py", line
 2267, in OnSetValue
 self.OnUpdateValues(event)
 629, in updateValuesHook
 self.SetStatusText(' '.join(map(gcmd.DecodeString,
 self.notebookpanel.createCmd(ignoreErrors = True))))
 TypeError
 argument 2 to map() must support iteration
 2267, in OnSetValue
 TypeError
 2094, in OnUpdateDialog
 self.parent.updateValuesHook()
 TypeError
 * d.rgb: same error pop-up, just once, same error message in console (see
 below). However, when I choose a raster band I get the same pop-up window
 which is blocked from view by the layer list selector and so I cannot
 click on the 'OK' button. Any GUI programme I have open is then completely
 blocked, only terminal is accessible allowing me to kill the process. This
 basically makes d.rgb unusable for me in the wxGUI.
 TypeError
 I'll add others if I stumble upon them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2826>
