[GRASS-dev] Fwd: Re: [GRASS GIS] #2820: v.surf.idw results seem seriously wrong and don't match r.surf.idw results
Moritz Lennert
mlennert at club.worldonline.be
Tue Dec 15 08:10:13 PST 2015
Paul,
Do you have any opinion on this ?
-------- Forwarded Message --------
Subject: Re: [GRASS-dev] [GRASS GIS] #2820: v.surf.idw results seem
Date: Tue, 15 Dec 2015 16:08:07 -0000
Reply-To: grass-dev at lists.osgeo.org
r.surf.idw results
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Vector | Version: 7.0.1
Resolution: | Keywords: v.surf.idw r.surf.idw interpolation
CPU: x86-64 | Platform: Linux
Comment (by mlennert):
Replying to [comment:6 mlennert]:
> Replying to [comment:5 mlennert]:
> > The result is quite unambiguous:
> > cat|idw_vect|idw_rast|owncal
> > 1|1545.09361138162|1388.6|1389.27
> > i.e. the calculated value is almost exactly identical to the
r.surf.idw result, while the v.surf.idw result is very far off.
> Using the '-n' flag in v.surf.index seems to solve the issue at least
partly: the value for the above point is now 1421, i.e. much closer to the
r.surf.idw and the calculated result (although still significantly
different).
> More exploration needed...
Ok, found part of the problem: distance was always left as dy*dy + dx*dx
without ever taking the square root. This obviously changes the weights as
1/10 is closer to 1/100 than 1/100 is to 1/10000...
The following patch solves this issue. Now I get the same result using the
-n flag as I do by calculation and with r.surf.idw. Without the -n flag I
now have a value of 1484 instead of the 1545 above. Indexing thus still
causes some issues. I think that these should be explored before applying
below patch. As an intermediate solution we could apply this immediately
and either reverse the meaning of the -n flag, making no indexing the
default, or we just completely take away the -n flag and always work
without indexing.
Index: vector/v.surf.idw/main.c
--- vector/v.surf.idw/main.c (révision 67143)
+++ vector/v.surf.idw/main.c (copie de travail)
@@ -468,7 +468,7 @@
if (i < nsearch) {
dy = points[row][column][j].north - north;
dx = points[row][column][j].east - east;
- list[i].dist = dy * dy + dx * dx;
+ list[i].dist = sqrt(dy * dy + dx * dx);
list[i].z = points[row][column][j].z;
i++;
@@ -486,7 +486,7 @@
/* go thru rest of the points now */
- dist = dy * dy + dx * dx;
+ dist = sqrt(dy * dy + dx * dx);
if (dist < maxdist) {
/* replace the largest dist */
@@ -514,7 +514,7 @@
for (i = 0; i < nsearch; i++) {
dy = noidxpoints[i].north - north;
dx = noidxpoints[i].east - east;
list[i].z = noidxpoints[i].z;
/* find the maximum distance */
@@ -527,7 +527,7 @@
for (; i < npoints; i++) {
As Paul is the one who introduced indexing, maybe he wants to comment...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:7>
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
