[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Wed Dec 16 02:03:42 PST 2015
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by mmetz):
Replying to [comment:33 neteler]:
> Replying to [comment:32 sprice]:
> > Hey all, just checking in. What is remaining to get this pushed to the
GRASS v7.1 code?
> For me two things are yet open.
> First:
> Replying to [comment:30 neteler]:
> > "User" comment: I would suggest to always activate the NULL file
compression by default, anything else would be confusing.
> --> not yet reflected in the patch (so, the meaning of the var
`GRASS_COMPRESS_NULLS` should be inverted or, better, implemented as
`GRASS_NOCOMPRESS_NULLS=1`. I have terabytes of uncompressed NULL files at
time and would like to get rid of wasting too much disk space.
That concerns #2349.
> Second:
> We need a patch for GRASS GIS 7.0 for backward compatibility, at least
for the NULL file compression. Which leads to the suggestion that either
RLE or BZIP should be used here since these two compressors are already
present in releasebranch70.
No, neither the generic RLE algorithm nor BZIP support is available in
relbr70. Note that CELL RLE compression is rasterlib-internal and tailored
for integer numbers with variable byte size. Therefore it does not make
sense to use the rasterlib-internal RLE method to compress null files
where the informative unit is one bit, not 1-4 bytes. For relbr70, null
files could be (un-)compressed with ZLIB's DEFLATE, other methods would
not be supported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:36>
