[GRASS-dev] wingrass daily buidls + addons temporary down
Helmut Kudrnovsky
hellik at web.de
Thu Dec 17 11:20:02 PST 2015
wenzeslaus wrote
> On Thu, Dec 17, 2015 at 2:01 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> wenzeslaus wrote
>> > python -m grass.gunittest.main --location nc_basic_spm_grass7
>> > --location-type nc
>> how do I know if the test has finished?
>> after:
>> C:\OSGeo4W\src\grass7>python -m grass.gunittest.main --location
>> nc_spm_08_grass7
>> --location-type nc
>> test_assertions from .\lib\python\gunittest failed (6 tests failed)
> test_numpy from .\lib\python\pygrass\raster failed (1 test failed)
>> test_raster_region from .\lib\python\pygrass\raster failed
>> the command line seems to be locked, not sure, if the tests are still
>> running?
> You can have a look to process manager what is still running there. There
> might be some problems [1] when RPC interface is used in temporal or
> pygrass but I'm not sure if it is the case now.
> [1] https://lists.osgeo.org/pipermail/grass-dev/2015-February/074037.html
testreport_ggunittest_winGRASS71svn_64bit.zip
<http://osgeo-org.1560.x6.nabble.com/file/n5241821/testreport_ggunittest_winGRASS71svn_64bit.zip>
attached the results. it seems there are no entries for the temporal tests.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-daily-buidls-addons-temporary-down-tp5240948p5241821.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
