[GRASS-dev] wingrass daily buidls + addons temporary down
Vaclav Petras wenzeslaus at gmail.com
Thu Dec 17 11:30:02 PST 2015
On Thu, Dec 17, 2015 at 2:15 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> wenzeslaus wrote
> > On Thu, Dec 17, 2015 at 2:01 PM, Helmut Kudrnovsky <
> > hellik@
> > > wrote:
> >> wenzeslaus wrote
> >> >     python -m grass.gunittest.main --location nc_basic_spm_grass7
> >> > --location-type nc
> >> how do I know if the test has finished?
> >> after:
> >> C:\OSGeo4W\src\grass7>python -m grass.gunittest.main --location
> >> nc_spm_08_grass7
> >>  --location-type nc
> >> test_assertions from .\lib\python\gunittest failed (6 tests failed)
> > test_numpy from .\lib\python\pygrass\raster failed (1 test failed)
> >> test_raster_region from .\lib\python\pygrass\raster failed
> >> the command line seems to be locked, not sure, if the tests are still
> >> running?
> > You can have a look to process manager what is still running there. There
> > might be some problems [1] when RPC interface is used in temporal or
> > pygrass but I'm not sure if it is the case now.
> > [1]
> https://lists.osgeo.org/pipermail/grass-dev/2015-February/074037.html
> in testfiles.html the last entries are:
> ./lib/python/pygrass/raster     test_raster     succeeded       6       6
>      0       100%
> ./lib/python/pygrass/raster     test_raster_img succeeded       9       9
>      0       100%
> ./lib/python/pygrass/raster     test_raster_region      FAILED  unknown
> unknown 0
> unknown
> no further entries.
This file is written as it runs individual tests. The same as in command
line.
> I have to stop for now and post the results.
According to that email linked above, Ctrl+C worked for me and interrupted
just the subprocess, so I got the subsequent tests as well.
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/wingrass-daily-buidls-addons-temporary-down-tp5240948p5241819.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151217/a01e6572/attachment.html>
