[GRASS-dev] [GRASS GIS] #2820: v.surf.idw results seem seriously wrong and don't match r.surf.idw results
trac at osgeo.org
Fri Dec 18 01:26:18 PST 2015
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Vector | Version: 7.0.1
Resolution: | Keywords: v.surf.idw r.surf.idw interpolation
CPU: x86-64 | Platform: Linux
Comment (by mlennert):
Replying to [comment:14 annakrat]:
> I hopefully fixed the bug in the indexing part and the missing sqrt in
r67211. Please test. Haven't looked at r.surf.idw yet.
Beautiful, thank you very much !
v.surf.idw results are now identical with and without the -n flag.
For the NC precipitation example, setting the flag (i.e. not using the
indexing method) actually make the module run faster. This merits some
more testing. From what I can gather from the PhD thesis and from the
code, it seems to me (but I'm really not sure) that the indexing is mostly
useful for situations where you have several input points per raster cell.
But in this case, why use interpolation and not aggregate statistics per
cell (à la r.in.xyz) ?
As for r.surf.idw, the NC precipitation data test gives almost identical
results (r.covar -r between v.surf.idw and r.surf.idw results gives
0.999883). There are some very localized differences that might merit a
look, but they might just be slight differences in distances calculations
and rounding.
However, using the OP's testing data, I still see the issue with the
r.surf.idw results.
In my eyes we should backport the fix to v.surf.idw and lower the priority
of this bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:16>
