[GRASS-dev] [GRASS GIS] #2820: v.surf.idw results seem seriously wrong and don't match r.surf.idw results
trac at osgeo.org
Sat Dec 19 09:17:32 PST 2015
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Vector | Version: 7.0.1
Resolution: | Keywords: v.surf.idw r.surf.idw interpolation
CPU: x86-64 | Platform: Linux
Comment (by annakrat):
Replying to [comment:22 mlennert]:
> I agree with you in principle, although when you have a module written
in one style, it might be a good idea to not mix too much with another, as
that might actually confuse and cause less readability.
Technically, both approaches (explicit passing of a pointer and using
static variable) were used in that function, so it's mixing it already.
> And in this particular case, I do find the static declaration within the
function more easily understandable and readable than the pointer magic
spread over all the code.
I spent quite a bit of time on debugging this code and I disagree. I even
think that the practice of using static variables caused this serious bug.
I am usually not comfortable with using pointers but in this case, it's no
magic, it's pretty standard case which is readable. And just because the
diff is just one line, it doesn't mean it's neat. I don't plan to change
anything now, but that's my opinion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:23>
