[GRASS-dev] [GRASS GIS] #2832: r.damflood return code
trac at osgeo.org
Sat Dec 19 09:49:42 PST 2015
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Addons | Version: unspecified
Keywords: r.damflood | CPU: Unspecified
Platform: Unspecified |
It seems that `r.damflood` [https://trac.osgeo.org/grass/browser/grass-
addons/grass7/raster/r.damflood/main.c#L1439 is not returning an integer
value from it's `main`] and as a result the actual return value is
[http://stackoverflow.com/a/4260070/592289 undefined]
{{{#!bash
GRASS 7.0.1 (nc_basic_spm_grass7):~/repo > r.damflood --overwrite
--verbose elev=dam_elevation lake=lake_map manning=manning
dambreak=total_dam timestep=0.01 tstop=20 deltat=10 h=H_
wavefront=wavefront
Reading input maps
Model running
Time: 10, writing the output maps
Writing the output final map H_20
Writing the output final map wavefront
GRASS 7.0.1 (nc_basic_spm_grass7):~/repo > echo $?
1
The problem with this is that when you invoke the script using e.g.
`grass.script.run_command()` you get an exception even though the
execution finished without problems. Not a huge deal but it caused me some
headscratching.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2832>
