[GRASS-dev] [GRASS GIS] #2598: g.extension compilation fails
GRASS GIS trac at osgeo.org
Sat Dec 19 13:17:51 PST 2015
  Reporter:  ewcgrass  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.0.3
 Component:  Default   |    Version:  svn-releasebranch70
Resolution:            |   Keywords:
       CPU:  x86-64    |   Platform:  Linux
Comment (by neteler):
 Replying to [comment:7 ewcgrass]:
 > The modules that still refuse to compile appear to be doing so because
 of some issues related to file permissions (??) and/or missing header
 files. For example, I have not been able to find geos_c.h anywhere within
 the /grass7.0.1svn-x86_64-unknown-linux-gnu-21_02_2015 directory, which is
 needed to compile r.stream.order, r.stream.snap, v.surf.mass,
 v.centerpoint, etc. Also, some errors appear to maybe be related to syntax
 errors; for example for modules v.transects and r.stream.basins.
 The file "geos_c.h" is provided by the "geos-devel" package which must be
 installed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2598#comment:12>
