[GRASS-dev] [GRASS GIS] #2683: grass 7 doesn't start in text mode on CentOS 7
GRASS GIS trac at osgeo.org
Sat Dec 19 13:46:49 PST 2015
  Reporter:  morenocomelli  |      Owner:  grass-dev@…
      Type:  defect         |     Status:  new
  Priority:  normal         |  Milestone:  7.0.3
 Component:  Startup        |    Version:  7.0.0
Resolution:                 |   Keywords:  centos
       CPU:  Unspecified    |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:6 neteler]:
 > From a (new) user's point of view, the initial part of the message
 >  "ERROR: Unable to start GRASS."
 > is a bit scary. It needs to be expanded and more friendly. Especially
 the word "ERROR" must be removed. Proposal, let's change it into something
 like
 >  "Welcome - You seem to run GRASS GIS the first time. Some settings need
 to be defined first. For this you can:"
 To be changed in
 lib/init/grass.py" line 1791
Ticket URL: <https://trac.osgeo.org/grass/ticket/2683#comment:7>
