[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
GRASS GIS trac at osgeo.org
Tue Dec 22 01:14:48 PST 2015
  Reporter:  khe          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Database     |    Version:  7.0.2
Resolution:               |   Keywords:  v.in.ogr
       CPU:  Unspecified  |   Platform:  Linux
Comment (by martinl):
 Replying to [ticket:2834 khe]:
 > g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_clip_strasse.shp",
 output=ort+"_strasse",overwrite=True, type="line",flags="o")
 btw, why do you use `o` flag?
 > It says: "DMBI-SQLite driver error: Unable to scan data: Fehler: Kann
 Daten nicht aus der Tabelle <S_weg> holen.
 Please exact command which fails.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:3>
