[GRASS-dev] g.gui.metadata - wrong bounds if not in latlon
Paulo van Breugel p.vanbreugel at gmail.com
Tue Dec 22 05:20:48 PST 2015
In addition to the issue mentioned below, it seems the fields for N, S, E,
W are mixed up in the GUI?
west bound => north bound
south bound => south bound
south bound => east bound
north bound => west bound
Just to be clear, what should be changed is the names of the fields in the
GUI (in the Geographic tab).
On Tue, Dec 22, 2015 at 2:11 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> When creating a new metadata file (INSPIRE template) for a raster layer
> the bounds are automatically filled in (under the Geographic tab). The
> bounds are given in the units of that mapset. For example, create a
> metadata file for a layer in the nc_basic_spm_grass7 mapset and the bounds
> filled in are given in meters.
> However, bounds should always be given in decimal degrees (as is also
> stated in the tooltip help). Besides being the standard, only if given in
> decimals the map in the pdf output is produced with extent.
> Would it be possible to have the tool fill in the bounds in decimal
> degrees, independent of the projection details of the mapset? If so, should
> I create a ticket for that?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151222/7ed287c4/attachment.html>
