[GRASS-dev] [GRASS GIS] #2658: [PATCH] v.to.db compactness gives wrong results in feet location
trac at osgeo.org
Tue Dec 22 05:21:18 PST 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.3
Component: LibGIS | Version: svn-releasebranch70
Resolution: | Keywords: v.to.db, units, area, compactness
CPU: Unspecified | Platform: All
Comment (by mlennert):
Replying to [comment:5 annakrat]:
> Replying to [comment:4 neteler]:
> > Will you apply the patch?
> I applied the patch, but needs more testing.
As mentioned, the patch has some side effects in terms of weird results in
terms of decimals.
I agree that it is better than leaving as is, but in the long run,
changing area calculations to always return current location units might a
better idea.
This would entail changing
[https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/area.c#L159
G_area_of_polygon()] and this will probably be quite invasive as any
library function or module calling this function would have to be updated.
In the meantime this should be backported IMHO.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2658#comment:6>
