[GRASS-dev] [GRASS GIS] #2824: g.gui.timeline throws exception when trying to display temporal dataset.
trac at osgeo.org
Tue Dec 22 06:13:15 PST 2015
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.1
Resolution: | Keywords: g.gui.timeline
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:7 annakrat]:
> There is already try except, do you want to hide the traceback?
Yes.
> But this is unrelated to the problem, is it working if you specify a
correct dataset?
Ok, if the dataset was created but is yet empty (simulating a new user or
so here):
GRASS 7.1.svn (NC_spm_temporal_workshop):~ > g.gui.timeline tempmean
File "/home/neteler/software/grass71/dist.x86_64-pc-linux-
gnu/scripts/g.gui.timeline", line 64, in <module>
main()
gnu/scripts/g.gui.timeline", line 57, in main
frame.SetDatasets(datasets)
gnu/gui/wxpython/timeline/frame.py", line 452, in SetDatasets
self._redraw()
gnu/gui/wxpython/timeline/frame.py", line 366, in _redraw
self._draw2dFigure()
gnu/gui/wxpython/timeline/frame.py", line 322, in _draw2dFigure
self.fig.autofmt_xdate()
File "/usr/lib64/python2.7/site-packages/matplotlib/figure.py", line
447, in autofmt_xdate
for label in self.axes[0].get_xticklabels():
File "/usr/lib64/python2.7/site-packages/matplotlib/axes/_base.py", line
2661, in get_xticklabels
which=which))
File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1214,
in get_ticklabels
return self.get_majorticklabels()
File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1168,
in get_majorticklabels
ticks = self.get_major_ticks()
File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1297,
in get_major_ticks
numticks = len(self.get_major_locator()())
File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 866,
in __call__
self.refresh()
File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 883,
in refresh
dmin, dmax = self.viewlim_to_dt()
File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 627,
in viewlim_to_dt
return num2date(vmin, self.tz), num2date(vmax, self.tz)
File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 345,
in num2date
return _from_ordinalf(x, tz)
File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 225,
in _from_ordinalf
dt = datetime.datetime.fromordinal(ix)
ValueError: ordinal must be >= 1
... sure, a user error but perhaps worthwhile catching it, too.
Then I filled "tempmean" with content, i.e. I used t.register. Now
works fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:8>
