[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
GRASS GIS trac at osgeo.org
Tue Dec 22 06:30:58 PST 2015
  Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Try the attached patch. This gives access to the v.db.select GUI, not a
 simplified version. An option would be to declare this as "Export
 attributes to csv file" and make separator=comma the default. Otherwise a
 wrapper module would be needed which provides most options as defaults,
 but then leaves less flexibility in terms of output formats.
 Personally, I would prefer to just provide the standard v.db.select
 interface.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2632#comment:4>
