[GRASS-dev] [GRASS GIS] #2836: GUI modeller: errors when changing order of commands (indexation of items seems wrong)
GRASS GIS trac at osgeo.org
Wed Dec 23 07:27:13 PST 2015
seems wrong)
 Reporter:  mlennert     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.3
Component:  wxGUI        |    Version:  svn-releasebranch70
 Keywords:  modeller     |        CPU:  Unspecified
 Platform:  Unspecified  |
 Using the GUI modeller in trunk and release70 I observe the following
 issues:
 1. first issue:
 * Add a command to the modeller
 * Add a second command to the modeller
 * Go to the items tab, select the first item and push on down (if you have
 more than two items this always works with the second to last item).
 Result:
   File
 "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
 -unknown-linux-gnu/gui/wxpython/gmodeler/frame.py", line
 1662, in OnMoveItemsDown
 self.list.MoveItems(items, up = False)
   File
 -unknown-linux-gnu/gui/wxpython/gmodeler/dialogs.py", line
 972, in MoveItems
 model.ReorderItems(idxList)
   File
 -unknown-linux-gnu/gui/wxpython/gmodeler/model.py", line
 123, in ReorderItems
 nextItem = self.items[newIdx+1]
 IndexError
 list index out of range
 2. Second (related) issue:
 * Add a loop
 * Add two commands and check the relevant boxes in 'List of items in loop'
 * Go to the Items tab
 * Select the second (lowest) item and push 'Up'
 Result: both commands now have the label of the second command (the one
 that was moved up), even if the command behind that name is the command
 that was first before. When you move the top one 'Up' then it is the loop
 (item number 1, but hidden in the item list) that gets renamed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2836>
