[GRASS-dev] grouping most important parameters in a 'main' tab
Panagiotis Mavrogiorgos pmav99 at gmail.com
Thu Dec 24 09:13:12 PST 2015
On Thu, Dec 24, 2015 at 6:56 PM, <grass-dev-request at lists.osgeo.org> wrote:
> Send grass-dev mailing list submissions to
>         grass-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/grass-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         grass-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-dev digest..."
> Today's Topics:
>    1. Re: grouping most important parameters in a 'main' tab
>       (Vaclav Petras)
>    2. r.category: wrong separator in examples (Helmut Kudrnovsky)
>    3. Re: [GRASS GIS] #2819: v.db.renamecolumn mysql error (GRASS GIS)
>    4. Re: [GRASS GIS] #2745: i.cluster: report file has wrong
>       linebreaks on Windows (GRASS GIS)
>    5. Re: [GRASS GIS] #2775: Hangs when closing db drivers (GRASS GIS)
>    6. Re: [GRASS GIS] #2775: Hangs when closing db drivers (GRASS GIS)
>    7. Re: [GRASS GIS] #2775: Hangs when closing db drivers (GRASS GIS)
>    8. Re: [GRASS GIS] #2759: v.rast.stats and mySQL (GRASS GIS)
> ---------- Forwarded message ----------
> From: Vaclav Petras <wenzeslaus at gmail.com>
> To: Moritz Lennert <mlennert at club.worldonline.be>, "Blumentrath, Stefan" <
> Stefan.Blumentrath at nina.no>
> Cc: Paulo van Breugel <p.vanbreugel at gmail.com>, grass-dev <
> grass-dev at lists.osgeo.org>
> Date: Wed, 23 Dec 2015 15:53:52 -0500
> Subject: Re: [GRASS-dev] grouping most important parameters in a 'main' tab
> On Wed, Dec 23, 2015 at 7:15 AM, Paulo van Breugel <p.vanbreugel at gmail.com
> > wrote:
>> On Wed, Dec 23, 2015 at 12:19 PM, Moritz Lennert <
>> mlennert at club.worldonline.be> wrote:
>>> In a response to #2632 [1], I changed v.db.select in trunk (r67337) in
>>> order to reorder parameters in the module GUI and group what I consider the
>>> most important parameters in a 'Main' tab.
>>> I know there has been much discussion about parameter grouping in the
>>> GUI before and I don't want to impose my choices here. So, I'm more than
>>> happy to revert if necessary.
>>> The main idea is to ease the use of module GUIs without giving up their
>>> complete power. In other words, simplify, without dumming down. If, for a
>>> module, there are some parameters that seem the most obvious ones to
>>> change, then why not regroup them in a 'Main' tab, while leaving the other,
>>> more specialised ones, in separate tabs ?
>> I am all in favour of this. Easier for the casual user and it means less
>> clicks for probably most user-cases. I guess it will not always be easy to
>> determine what are the most important / common parameters, but for this
>> module I think you got them all right under the main tab.
wrt to the name of the tab, instead of "main", "common" might be more
accurate.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151224/e8dd4584/attachment.html>
