[GRASS-dev] results in winGRASS7 32bit vs 64bit: should they be identical?
Helmut Kudrnovsky hellik at web.de
Wed Dec 30 03:08:47 PST 2015
>> any ideas if they should be identical?
>Testing like this will likely show differences due to CPU precision etc.
in this quick test it's the same machine, running 32bit and 64bit winGRASS
binaries ...
>The test needs to be implemented in a different way, using an epsilon.
>Essentially, something like this:
>if(abs(map_A - map_B) <= 1e-8,... )
thanks for the hint.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/results-in-winGRASS7-32bit-vs-64bit-should-they-be-identical-tp5243280p5243283.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
